Results 1 to 4 of 4
    Osceola, AR
    Default I use the fireplace all the time, there is nothing wrong with it
    Sometimes you can only shake your head and walk away...
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    MONTREAL QUEBEC-CANADA
    Default Re: I use the fireplace all the time, there is nothing wrong with it
    I will post a shot of last weeks. fire box when I get back in the office. Built in fire suppression.
    There was bulk water stream down the fire box walls.
    Maybe it was installed in a unit with a sub panel.
    Looks like someone removed the damper and a few firebricks to get a chimney liner down for a wood insert stove that was later removed but the fireplace was never repaired. Some firebricks, parge with Chamber Tech 2000 and a top mounted damper and Bob's your uncle unless there are other issues with it. About a $1,500-2K repair depending upon local market conditions. Look on the bright side: without a pesky throat damper someone can stand up and hand parge the smoke chamber right up to the first flue tile making a smooth transition that reduces the chance of smoke spillage while improving the chamber's dire durability. Level II inspection triggered.
Tags for this Thread
