    Daniel Island, SC.
    Default Metal Chimney distance from an operable window and above soffit
    Need clearances for this chimney exhaust from an operable window and above soffit. Picture attached
    Thanks, Jim
    Chicago
    Default Re: Metal Chimney distance from an operable window and above soffit
    8' clearance from vertical walls so that doesn't cut it. It's more accurately a B-vent and not a chimney.
    Mike Lamb
    Inspection Connection, Inc.
    http://www.inspection2020.com/
    It's 8' from the sidewall, minimum, or 2' above the roof above.
    It's also, as I recall, 10' from a building opening (windows, doors, soffit vents, etc.
    so so, California
    Next time get the manufactures info off the appliance. you can look up the manual which gives you the clearances.
    Feb 2014
    Pittsburgh, PA
    Great answer! That info can help with soo many things in your reports "manufacturers requirements"
    Michael Ashburn, Ashburn Inspections
    PittsburghInspector.com
    724-516-1665
    What type of appliance was that vent pipe serving? Some appliances allow significantly reduced clearances. Pellet stoves are among some that do.
