04-13-2018, 03:44 PM #1
Metal Chimney distance from an operable window and above soffit
Need clearances for this chimney exhaust from an operable window and above soffit. Picture attached
Thanks, Jim
04-13-2018, 04:08 PM #2
Re: Metal Chimney distance from an operable window and above soffit
8' clearance from vertical walls so that doesn't cut it. It's more accurately a B-vent and not a chimney.
04-14-2018, 08:19 AM #3
It's 8' from the sidewall, minimum, or 2' above the roof above.
It's also, as I recall, 10' from a building opening (windows, doors, soffit vents, etc.
04-29-2018, 11:01 PM #4
Next time get the manufactures info off the appliance. you can look up the manual which gives you the clearances.
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
05-09-2018, 06:06 AM #5
05-09-2018, 06:22 PM #6
What type of appliance was that vent pipe serving? Some appliances allow significantly reduced clearances. Pellet stoves are among some that do.
