Results 1 to 4 of 4
Thread: Old Gas Shut-off for Appliances
11-29-2019, 04:05 PM #1
Around these here parts....Over the last few years, I've had several HVAC techs & plumbers tell me that the old tang gas shut-offs that require a tool to operate must be replaced with hand operable shut-offs anytime a gas appliance is replaced. But recently, one of our AHJs told me that it was a good idea, but not required. I tried to find some mention of it in the IRC but cannot. G2420 covers locations of shut-offs and access, but I don't see any comment on whether the valve requires a tool or hand to operate it.
Am I missing something?
Similar Threads:If you choose not to decide, you still have made a choice.
11-29-2019, 05:55 PM #2
Re: Old Gas Shut-off for Appliances
May be addressed in one of the standard referenced in G2420 for gas valves, but you would need the standards to find out.
12-18-2019, 09:14 AM #3
As far as if replacing an appliance it would be good common sense at the least and the code is vague at best. I do know whenever we were at a customers house on a leak call we greased all of the old style valves , it helped prevent recalls and also made them a lot easier to operate. Today I don't believe the companies care about the customers that much since it is all time and money.
12-19-2019, 06:50 PM #4
Depends on your local jurisdictions' requirement for accessibility. Some AHJ's require that it not require special tools or keys to operate a valve (differences usually applied for readily accessible vs. accessible , etc..).
