Results 1 to 12 of 12
Thread: Crashed and Over
12-27-2019, 02:12 PM #1
Crashed and Over
Crashed my inexpensive SharkSpark drone. R.I.P.
I need suggestions for a new bird. I've looked until I cannot look further. Too many choices. I would like one that is easy to operate, takes 4K video, GPS, self-returning, auto-hovering, etc. And, most importantly, under $10,000
. Please send me your ideas.
Thanks in advance.
Texas Inspector
http://www.texasinspector.com
12-29-2019, 08:16 AM #2
Re: Crashed and Over
Texas Inspector
12-29-2019, 08:35 AM #3
Aaron,
Maybe not many HIs use drones?
Or maybe it was that "under $10,000" amount that gave those who do the willies?
https://247wallst.com/consumer-elect...000-on-amazon/
https://www.amazon.com/DJI-Inspire-B...keywords=drone
https://www.dji.com/inspire-1-pro-and-raw
12-29-2019, 08:43 AM #4
JP:
I edited this several times beginning with a $500 limit and increasing it incrementally up to $10K (like I would ever pay that for something I can crash into the nearest tree) in hopes that the dearth of comments was due to my low ante . . .
In my area every other HI is hawking drone use. Maybe they are not on this forum. Maybe they have moved on to the next plane, leaving more business for me.
Best in the New Year
Aaron
Texas Inspector
12-29-2019, 03:08 PM #5
I saw the first post (at $500) and didn't check back in till now. I had nothing to add to the inquiry at that dollar amount.
The stability of the Mavic series, combined with overall ease of use, make it a good choice. I don't like that drones all squawk back to the mother ship every time you use one, maybe that can be "modified" or similarly changed.
The new proposed FAA rule about all drones sending out a "pulse beacon" and sending your flight plan over the open internet before every flight is a bit much.
12-29-2019, 03:17 PM #6
Texas Inspector
12-29-2019, 03:39 PM #7
When one considers that drones are now invading air space previously allowed to other aircraft, piloted aircraft, and while the drone operator is safely on the ground, the drone is not ... and neither are the other aircraft which the drone could have an impact ... advance notice of a flight seems to be the least one would expect of a drone/drone operator.
12-29-2019, 03:50 PM #8
JP
Agreed. See https://www.faa.gov/uas/commercial_operators/
Texas Inspector
12-29-2019, 04:24 PM #9
Agreed, but, I would expect some sort of alternative, such as a limiting device to keep the thing less than 50 feet or some other reasonable height.
There are no problems or restrictions with a telescoping camera pole, and most HI's use these things ("drones") as a " remote-camera on a tether".
12-29-2019, 04:56 PM #10
See your previous response.
Originally Posted by Dom D'Agostino
A very good reason that a tether should not be allowed, same with height above ground limitations - can be modified.
Maybe if a height above ground limitation which was unalterable, and (a critical vompnonent) an altitude signal relay which verifies height above ground ... a violation results in immediate self-destruction of the drone.
12-30-2019, 05:00 AM #11
[/QUOTE]Maybe if a height above ground limitation which was unalterable, and (a critical vompnonent) an altitude signal relay which verifies height above ground ... a violation results in immediate self-destruction of the drone.[QUOTE]
JP
A bit Draconian, but effective. Might be peripheral damage though.
Texas Inspector
12-30-2019, 06:18 AM #12
