    Default Inspection needed in Lumber Creek florida
    I know this is not the right forum, but my son who is a United States naval officer is buying a house From LG homes Lumber Creek Florida. I am old and retired in Southern California so I cannot perform inspection. Any help would be greatly appreciated.
    Information they have sent me:Our Homes are structurally engineered / Steel and fiber reinforced concrete monolithic slab.
    All homes are built to withstand 130 MPH
    10 Year Structural Warranty
    6mil polyethylene sheathing vapor barrier, with all joints taped and sealed.
    Framing shall be of size and strength needed to satisfy local codes and architectural plans.
    Single 2"x 4" bottom sole plate.
    Exterior and interior walls 2"x 4" wood studs.
    All homes are sprayed with Massey Pest Prevention Plus and also have a million dollar bond for termites with the Sentricon bait system in yard.
    Roof is the 3D Architectural fiberglass shingels which has a 30 year warranty.
    Tyvek House Wrap 10 year limited warranty
    James Hardie Fiber Cement Siding are specifically designed for Florida climate 30 year non-prorated warranty
    16 SEER Lennox Air Conditioner with 10 year warranty
    Rain Bird Sprinkler system WIFI Capable front and back yard
    Garage Door opener WIFI capable
    Whirpool appliances have 1 year warranty
    Paint of exterior and interior is Sherwin Williams with 5 year warranty of any peeling, fading, chalking and or bubbling
    All faucets are Moen with limited lifetime warranty
    Badger Garbage Disposal with 1 year limited warranty
    Kwikset Locks lifetime warranty
    Rheem 40 gal quick recovery water heater with 6 year warranty
    Therma-Tru Doors with limited warranty for 30 years
    1 year workmanship warranty through LGI Homes
    Windows are fiber glass white frame, clear insulated glass with PP2 Low E2 Glazing
    Insulation is minimum R13-R19 in the walls and a R-38 blown insulation in attic
    Installed baffles from soffit to attic for ventilation (Our Homes are EXTREMELY efficient)
    Default Re: Inspection needed in Lumber Creek florida
    The Fairview is 1399 Sq Ft
    The Price of the Sunnyside is $219,900.00
    Land Taxes $232/ Month
    Homeowners Insurance $44/ Month
    HOA $672 Annually $56 a month
    No fire sprinkler requirement in new construction?
    Sep 2020
    USA
    Quote Originally Posted by Andrew Buckwell View Post
    New house or New construction? For New construction yes fire sprinkler are required, but before investing or buying a new house property inspection is required for sure!
    Quote Originally Posted by Margarita Keyys View Post
    New house or New construction? [SIZE=1]For New construction yes fire sprinkler are required, ...
    Confused about more than just "New house or New construction?" because fire sprinklers are NOT required in Florida (the question was asking about a place in Florida). Florida statute specifically prohibits requiring fire sprinklers in one and two family dwellings ... with ONE exception: unless such a requirement was locally adopted before the date stated in the statute, and there is ONLY ONE AHJ which had such locally adopted before that date (and Lumber Creek is not even in the same part of Florida as that one AHJ is).
    Hopefully, this is not an indication of the accuracy (inaccuracy) of the information in the reports provided by the company which that link goes to.
