    Comer, GA
    Default sand deposits at hearth extension
    These sand deposits were found on an inspect of a house unoccupied for an unknown time period. Massive chimney column rises from ground all the way up and through.
    Mar 2017
    California
    Default Re: sand deposits at hearth extension
    Quote Originally Posted by jim baird View Post
    Brick termites? Somebody throwing sandbags against the fireplace for fun? The answer to this sand deposit mistery is awaitng further investigation by you. oo
    Improper mortar mix
    http://www.jjeffzehnder.com/
    May 2009
    Washington State
    Mason-ry Bees ! Probably weren't Union -
    Looks like efflorescence on some of the bricks on the surround. My guess is moisture penetration through the chimney and powdering up of the brick from moisture. Any issues on the exterior chimney structure like damaged pointing or a damaged mortar cap?
    Sep 2009
    leonardo, new jersey
    I can?t tell from my phone photo but masons years ago and today fill the void behind the fire brick and masonry block with sand , allows for thermal expansion with out the rigidity of cement or brick causing resistance.
    Joseph Ehrhardt
    Aug 2020
    California
    Quote Originally Posted by Elizabeth Chambers View Post
    I also first thought of brick termites. But can't be sure. Did you find any specific thing @Jim?
    May 2009
    Washington State
    I agree with Nick about the efflorescence. I've seen it when fireplaces are located in basements that aren't occupied / kept warm.
    Efflorescence but also mortar deterioration from moisture. Whether moisture adsorbed into the surface then absorbed on the exterior face and crown or damp rising, water will be driven inwards and down by gravity and vapor diffusion. Once the salt concentrates, its like a magnet for more water and thus propagates an insidious cycle. The cool surface of a basement fireplace makes for a nice condensing surface for humid basements. Most people close the damper thus cutting off ventilation. Of course, being in a negative pressure zone, humid outdoor air would be drawn down the flue into the basement so correct the house's pressure regimes.
