Thread: GFCI/AFCI testing question
11-15-2020, 05:19 PM #1
It's been a looooooong week so maybe the brain is totally dead here... but here it goes:
- There is an office room at the front left of the house which is adjacent to the kitchen.
- When i was checking the office room's receptacle outlets with a 120V AC receptacle tester
with a GFCI push test button to see if there were any open ground, neutrals, etc., I
accidentally pushed the GFCI test button.
- I was surprised to see that all the outlets in the office were GFCI protected as they tripped
off when I pushed the test button.
Could it be possible that the office room's AFCIs could be tripped with a GFCI tester? Could this be an indication of an issue with the AFCIs?
Thanks for any insight!
11-15-2020, 06:24 PM #2
Re: GFCI/AFCI testing question
Roy, Sounds like they made the formal dining room an office. Since it is adjacent to the kitchen I think that's what happened. Dining rooms & breakfast nooks will have GFCI outlets in newer homes.
I think your tester is OK.
11-15-2020, 07:58 PM #3
How did you restore power to the receptacle outlets in this room?
Some outlet testers will trip certain AFCI breakers. I thought that problem was old and forgotten, but who knows.
It's possible the breaker was a combo GFCI/AFCI breaker.
11-16-2020, 07:50 AM #4
I would bet that it was protected with a GFCI device for some other reason. I have a few receptacles in my new house that are protected that aren't required just because it was easier to use a GFCI/AFCI combo breaker for the entire circuit instead of splitting them up with local GFCI protection.
11-17-2020, 09:03 AM #5
Some early, and some possibly current, AFCIs have a built-in GFCI that is not the "personal protection" variety. That is, they trip at a higher level but, they trip with the same tester.
These are not the same animal as an AFCI/GFCI combo breaker where the GFCI part of the breaker can be used to protect receptacles.
12-06-2020, 04:32 PM #6
12-08-2020, 12:35 PM #7
The AFCI device is usually the breaker for the circuit.
