    Aug 2020
    texas
    Default GFCI/AFCI testing question
    It's been a looooooong week so maybe the brain is totally dead here... but here it goes:
    - There is an office room at the front left of the house which is adjacent to the kitchen.
    - When i was checking the office room's receptacle outlets with a 120V AC receptacle tester
    with a GFCI push test button to see if there were any open ground, neutrals, etc., I
    accidentally pushed the GFCI test button.
    - I was surprised to see that all the outlets in the office were GFCI protected as they tripped
    off when I pushed the test button.
    Could it be possible that the office room's AFCIs could be tripped with a GFCI tester? Could this be an indication of an issue with the AFCIs?
    Thanks for any insight!
    Default Re: GFCI/AFCI testing question
    Roy, Sounds like they made the formal dining room an office. Since it is adjacent to the kitchen I think that's what happened. Dining rooms & breakfast nooks will have GFCI outlets in newer homes.
    I think your tester is OK.
    How did you restore power to the receptacle outlets in this room?
    Some outlet testers will trip certain AFCI breakers. I thought that problem was old and forgotten, but who knows.
    It's possible the breaker was a combo GFCI/AFCI breaker.
    I would bet that it was protected with a GFCI device for some other reason. I have a few receptacles in my new house that are protected that aren't required just because it was easier to use a GFCI/AFCI combo breaker for the entire circuit instead of splitting them up with local GFCI protection.
    Mar 2009
    Colorado Front Range
    Some early, and some possibly current, AFCIs have a built-in GFCI that is not the "personal protection" variety. That is, they trip at a higher level but, they trip with the same tester.
    These are not the same animal as an AFCI/GFCI combo breaker where the GFCI part of the breaker can be used to protect receptacles.
    Jan 2011
    Guelph,Ontario
    It can be a real issue at times,trying to figure out were the reset button is.
    Mar 2009
    The AFCI device is usually the breaker for the circuit.
