Results 1 to 32 of 32
    Denver, Co
    Cool Interesting P Traps
    I am always amused by the plumbing I find under kitchen sinks.
    Default Re: Interesting P Traps
    Those are outstanding.
    I'm partial to the trombone one myself.
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Talking Re: Interesting P Traps
    Nice trap on the first one, it really doesn't matter if the trap is on it's side, it'll still work.
    Lee,
    Not following you there.
    A trap must be vertical.
    Or did I miss the smiley face you intended?
    Rick Maday's Avatar
    Rick Maday Guest
    The first one is a new "Z" trap!
    Then there's the "trap-not" or, "I don't have to show you no stinkin traps!"
    And the shop-vac trap...
    Jerry Mc.,
    Made with radiator hoses no less!
    Wonder what they are trying to 'radiate'?
    Dom,
    Oh the ingenuity of the American People, no wonder we are so far along as a developing nation ...
    Lee Nettnin Guest
    Smile Re: Interesting P Traps
    Yeah, I forgot my smiley, I was just being sarcastic.
    Anacortes, Washington
    Red neck ingineeering at is finest.
    Great stuff,
    //Rick
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    You don't need a trap when you're just running the utility tub drain straight into your basement water control system. Let the sump pump take care of it.
    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    While likely an Approved Installation for much of the State of PA, I would Not Agree.
    Holladay, UT
    What would concern me more is the exposed splices in second picture.
    Not a material common in my area, any issues when you "mix-and-match" like this?
    Not an issue with mixing different materials, but that drain installed with that tee like it is, the disposer is going to try to pump water back up into the sink before it ever thinks of going down, and, water from the sink, if drained rapidly, could readily back up into the disposer before it goes down the bottom leg of the tee.
    That tee should have been installed with the inlet/outlet on the vertical, with the disposer (or the sink) entering on the side inlet.
    Richard Rushing's Avatar
    Richard Rushing Guest
    Yup... that dishwasher will try and back-up the sink almost every time. That set-up is a like having a crystal ball-- easy to tell the future.
    Rich
    Then there is this pretty little beauty (drum) I just found under a home two days ago. Kinda gets you all happy under the home when you see one of these because they are just too far between sightings...
    Rich
    David Banks's Avatar
    David Banks Guest
    Rich
    Seen about once a week around old New England.
    Blaine Illingworth's Avatar
    Blaine Illingworth Guest
    I like the anti-rodent pie tins on the water pipes myself.
    Blaine
    Blaine,
    I believe those would be termite shields, assuming the pipes come up out of the ground.
    From the looks of the floor joist they found another way in.
    Jack Ahern's Avatar
    Jack Ahern Guest
    I see a few a month in the Boston area.
    I've seen lead, brass, and PVC drum traps
    May be a code (?) requirement in the State of Maine. I have five of them in Bridgton. I have a seminar in Augusta next week regarding "Maines new internal plumbing code". This should be interesting!
    Go Pats
    How we do it in Chicago - there were a dozen more like these at this morning's inspection:
    Over the years, I'll bet I've found at least 20 of those leveling jacks under homes...
    I guess that's what keeps the manufacturers in business
    RR
    Over the years, I'll bet I've found at least 20 of those leveling jacks under homes...I guess that's what keeps the manufacturers in business
    RR
    Well, these guys had a jones for jacks, thats for sure:
    Ooou Spare Jacks,
    Fuquay Varina, NC
    Since this is evolving in great novice moments.
    Here is the new floating coil box system designed to let you know if the primary gets obstructed by blowing water mist out of your registers.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Don't know if it's clear in the picture, but that jack is supported by the table.
    Sparky the electrician invents new trap: If there should ever be a clogged drain the spark plug ignites the methane gas build-up blowing the drain line clear.
    Looks like a winner to me?
    Mustang
    Thumbs down Re: Interesting P Traps
    Sorry Jerry your wrong about Michael's p-trap tee. It has a divider built into the tee that stops the flow of water through the tee. The water has no place to go but down.
