Results 1 to 4 of 4
Thread: steamer-tpr
03-12-2008, 04:09 PM #1
steamer-tpr
I tested a steamer today and noticed that the bathroom window was fogging up on the outside. I went outside and found steam coming out the tpr drain line. I dont know if this is normal to relieve pressure or if there is a problem? I an guessing that is not how it is supposed to work. I have never had this happen before. Any know anything about steamers help is appreciated. It was a Steamist electric unit.
03-12-2008, 05:33 PM #2
Re: steamer-tpr
The steam generator's TPR valve should not discharge during normal operation.
03-12-2008, 08:29 PM #3
Re: steamer-tpr
roger... thanks
03-14-2008, 06:32 PM #4
Re: steamer-tpr
Was it the T&P or the drain line for the tank?
Some systems have an automatic purge valve that drains all the hot (and steamy) water after each use.
