Results 1 to 16 of 16
Thread: Weaved valley
03-13-2008, 01:54 PM #1
Weaved valley
one side of the roof is 8/12 and the other side is 10/12. Using ELK(no tabs) shingles. Weaving valley.How many courses up do i go before i double row to keep the parting line in the center of valley?And which pitch or side of roof should i start the first shingle? In otherwords which pitch should be on the bottom of weave? thanks, any help would be fine
Similar Threads:Last edited by jeff king; 03-13-2008 at 01:56 PM. Reason: put closed instead of weaving
03-13-2008, 02:29 PM #2
Re: Weaved valley
03-14-2008, 04:53 AM #3
Re: Weaved valley
http://www.elkcorp.com/application_i...ownSpecSht.pdf
Yes you can weave elk.
03-14-2008, 05:44 PM #4
Re: Weaved valley
Well?
03-14-2008, 07:29 PM #5
Re: Weaved valley
03-16-2008, 10:59 AM #6
Re: Weaved valley
Well It's been a year know , no leaks .
03-16-2008, 09:00 PM #7
Re: Weaved valley
To answer, the higher or steeper slope should be overlapping the bottom.
JP-- that was a great reply!!
LMAO
03-17-2008, 12:33 AM #8
Re: Weaved valley
No help whatsoever, why are you on here?
03-17-2008, 12:38 AM #9
Re: Weaved valley
Thank you Scott your advice was very helpful, could'nt have done it without it.
03-17-2008, 05:22 AM #10
Re: Weaved valley
03-17-2008, 07:27 AM #11
Re: Weaved valley
Are you a monday morning armchair quarterback? You sure act like one.
03-17-2008, 07:29 AM #12
Re: Weaved valley
Glad to have helped. But I must agree with Jerry & Richard, the valley is not woven correctly from what I can tell in the pictures. A while back somebody posted a picture of a correctly woven valley, it would be great to find that picture and look at the difference in it and yours.
With that heavy of a shingle it might have been better to have gone with a cut valley. Weaving dimensional shingles like you have is very difficult.
03-17-2008, 07:36 AM #13
Re: Weaved valley
I found the picture of the valley. It is from Roger Robinson's company in CA, Star Inspections. Now this is a 3 tab shingle but the valley part should look the same.
03-17-2008, 07:49 AM #14
Re: Weaved valley
Nope.
You get to play in the big game.
I only get to come in and show you where you are wrong ... in front of the judge.
If you come to learn, or help teach, do so. If you come to criticize ... we can all play that game together, and you will lose.
Besides, now that you are playing 'that' game ... it is not "Weaved valley", it is "woven valley".
And "monday" is "Monday".
03-17-2008, 06:18 PM #15
Re: Weaved valley
Woven valley = Sure Leak. Bad choice in snow country for sure, and I believe equally bad everywhere.
Having done roofing for 35 Years, I have never found one that I removed for reroofing that had not leaked.
Bad choice, bad choice, bad choice.
03-24-2008, 01:32 PM #16
Re: Weaved valley
When you have two diffrent pitches always start with the low pitch side first. When the shingles are woven they will cross each other in the center of the valley. The "cross" or where they overlap and kind of looks like a "X" will drift out of the center of the valley after a few courses and then you have to double the low side before bringing the high side over to bring that back to center.
