Results 1 to 4 of 4
    allen elliott's Avatar
    allen elliott Guest
    Default Service Clearance
    What is the minimum clearance over a detached garge or other structure for a overhead service line. 18" or 3 feet? The service does not attach to the structure it passes over it. The roof on the detached garage is 4:12 and is metal. I hope someone can clear this up for me. Thanks
    Default Re: Service Clearance
    Quote Originally Posted by allen elliott View Post
    Clearance 'above' the 4/12 roof is 3 feet.
    Clearance 'above' the 4/12 roof at the final drip loop where it is attached to the mast and 'above the overhang' is 18 inches.
    Allen
    Refer NEC 2005 Article 230-24 (A) and read exceptions.
    allen elliott Guest
    Thanks for help.
