Results 1 to 4 of 4
    David Block's Avatar
    David Block Guest
    Default Ever seen a flue like this?
    I was on the roof of this house and took a peak down the one of the flues and this is what I saw. There were two flue tiles coming out of the chimney chase. One was for the furnace and water heater. The one in the picture was for the fireplace in the basement and the fireplace in the living room. The picture doesn't do this setup justice. There were two copper gas lines retrofitted into the fireplaces with one going through the cleanout door and the other, they just knocked a hole in the side of the flue liner and fed it through that way. It was quite the setup.
    Default Re: Ever seen a flue like this?
    I adjusted the brightness and contrast to show the inside better.
    David Block Guest
    Thanks Jerry, that really brings out the details much better.
    Cool Re: Ever seen a flue like this?
    You're saying two fireplaces shared this one common flue? Let me get this straight:
    common vented fireplaces
    copper gas lines in the flue
    tiles broken out
    mis-aligned tiles
    mortar missing/ eroded
    gas line routed through chimney wall???
    So, what was your recommendation or comment on this? Good catch.
    Bob
