Results 1 to 15 of 15
Thread: 2 year old roof
    william siegel's Avatar
    william siegel Guest
    Default 2 year old roof
    roof passed all county inspections. How would you write this up. Thanks
    Default Re: 2 year old roof
    "Improper and unprofessional application of tar at flashing areas and roof penetrations - tar seals are temporary and will eventually leak - improper termination of asphalt shingles at overlap with stone aggregate roof surface - have roofs serviced by a professional roofer and all repairs made as needed."
    David Banks's Avatar
    David Banks Guest
    William. I Ditto Nick. The flat roof looks in poor condition.
    The flat roof is shot. I dont know why they didnt replace it when theyrreplaced the main roof. There should be no need for the tar seals. I am wondering if this is how they install in a different part of the country. A lot of these roofs werer put on by out of staters after Hurricane Wilma.
    The roofer is either brain-dead or a major stock holder in Henrys?
    http://www.henry.com/fileadmin/pdf/d...3_techdata.pdf
    Daniel Stone's Avatar
    Daniel Stone Guest
    Good God!
    Classic case of good materials going to waste. Probably nailed improperly too.
    Ditto what others have said but I have a comment/question.
    Of course it passed municipal inspection, it probably looks good from the ground. Am I being too cynical or do municipal inspectors actually have ladders and go up?
    Just curious. I can assure they don't up here.
    markus,
    They do not carry their own ladders - too much liability I guess. Most of the time they do not go up on the roof (although now that it has slowed down after the hurricanes more of them are going up), but they will fail the inspection if there is not ladder left by the roofer, and sometimes they will fail it if the ladder is not secured to the roof at the eave or gutter.
    The Treasure Coast
    Looks like typical roof work!
    Just like the roofs fond here: Roof
    Bill,
    The reason that the flat roof wasn't done is because a permit wasn't pulled, just a guess.
    The city inspectors do not generally go on the roof, although they make you strap a ladder to your roof. They also do not go in the attic to check on the nailing. They rely on an affidavit from the roofer.
    www.magnuminspections.com
    Bill, WOW, that sure is different than here.
    In the city there is no one coming out to look. In the burbs, depending on which one, maybe an appointment.
    Usually in the burbs, the muni insp wants to know what day a roofer is starting so they can verify 15# felt and ice/water shield 1st 3 feet up from gutter line. After that they 'might' do another drive-by.
    As far as not passing a roof, it has to look really bad from the ground.
    Kade's Avatar
    Kade Guest
    A question i've never got an answer to: If an inspector comes on my jobsite, and climbs on the roof, should they be required to wear the same safety gear my employees/subs have to? (harness, etc.)
    Quote Originally Posted by Kade View Post
    It's your jobsite, you can dictate any policy you want.
    The Treasure Coast
    A question I've never got an answer to: If an inspector comes on my job site, and climbs on the roof, should they be required to wear the same safety gear my employees/subs have to? (harness, etc.)
    It may be your "job site", but it may not be your home. It would most likely be the homeowners decision if he wanted the inspector to take off his shirt, put on shorts and tar stained sneakers, then traipse around on a new roof.
    To be serious, I haven't seen any "safety devices" worn by any roofers or their crews on any single story roof. For that matter, second story as well.
    I have seen some use safety harnesses on hi-rise buildings, but that is about it.
    I believe the OSHA requirements are only for employee's of a company, and not for an owner. Most home inspector's are owner's of the company and would not be required to wear the gear.
    You "can", but if you want your inspection ...
