Results 1 to 11 of 11
    Default Type of Insulation?
    What type of insulation is this? Having a senior moment here.
    Anyone, anyone, Bueller?
    Also check your pictures well. Embarrassed to say, I had not noticed that the flue pipe was separated till I got back to the office and scanned my pictures. I was more into the opening around the flue and the type of insulation at that moment. My bad.
    David Banks's Avatar
    David Banks Guest
    Default Re: Type of Insulation?
    Rick. I am not sure from pic but maybe Loose fill Balsom or Rock wool. Most of the Cellulose I see is white.
    Are you sure that flue is split? It looks like it's at a twisting elbow which could explain the offset look.... just a thought.
    I'm thinking cellulose - most of what I see is either that color or a dark gray color.
    You didn't mention, but I'm sure you got, the insulation around the vent/flue. Looks like a nice insulation baffle around that vent/flue ... sure did keep the insulation in around it pretty darn good.
    I don't see it separated either, looks like a fire stop support with a support ring around the vent/flue.
    What the opening does do, though, is allow you to see that there are no supports holding that vent/flue (other than the fire stop with support collar). As I under it, each section needs to be supported???
    Jim Zborowski's Avatar
    Jim Zborowski Guest
    From the brown coler and texture, I'm thinking maybe Zonalite.
    Cellulose
    Hard to tell at that resolution, but it looks most like cellulose, does NOT look like the Zonolite I see in my area. My first take was also that that’s an offset rather than a disconnected flue - again, hard to tell at this resolution. Also, is that lower portion single-wall pipe? In either case, is there sufficient clearance where it appears to penetrate the ceiling below?
    BTW, this is why 1) I don’t do on-site reports and 2) I shoot lots of pics at full resolution (I realize the resolution in Rick’s photo is likely reduced for posting here).
    Richard Rushing's Avatar
    Richard Rushing Guest
    No doubt in my mind that this is cellulose.
    rich
    Montreal, Quebec
    How about peat moss? Seen it in a few older homes here, have a picture somewhere, complete with the paper bags it came in.
    Garland, TX
    Quote Originally Posted by David J. Smith View Post
    David, thanks for the pic. I've looked for one to verify material for one of those "arguable deals" in the past.
    It's not common around here but I've found this in at least 4 homes that I can recall.
    It was fairly compacted and combustible, when "tested outside of the attic."
    Don't assume that the chopped material is cellulose.
    Most old and new cellulose that I run across is greyish not brown, but there may be some brown around.
    I advised removal and replacement with new material.
    Fuquay Varina, NC
    cellulose
    In older homes around here the stuff that is exposed turns brown but if you dig down a bit it should be grayish color. Some times you can see the print on some of the particles. Be a great puzzle.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
