Thread: trap
    Default trap
    don't we need a trap at all condensate drains?
    Mike Huppi's Avatar
    Mike Huppi Guest
    Default Re: trap
    The pump is considered the trap. I would recommend the lines be run separate for drain lines, I can not tell if the shut off is wired for the pump, so that it will turn the furnace and A/C off if the pump stops working if this is in a living space.
    Default Re: trap
    Yes.
    I've never seen a condensate pump installed such that it meets the requirements of a trap.
    There should be a trap between the AHU and the condensate pump.
    Chris Ethridge's Avatar
    Chris Ethridge Guest
    Default Re: trap
    We always putt a trap before the condensate pump. that setup in the picture will stink up the house during the heating season. this is why you should put it there
    Mr Bill's Avatar
    Mr Bill Guest
    Default Re: trap
    Yes.
    Your exactly right and if you look at the picture how is that pump set up going to keep out any odors? JMHO
