Results 1 to 11 of 11
Thread: Siding Type?
05-11-2008, 08:23 AM #1
Siding Type?
There is this siding that seems to be a compressed fiber board or something. Once it ages, it flakes and looks & feels like cardboard. Any clues?
Sorry for the lack of clarity, but maybe there's enough here between the 2 images to be helpful:
http://img102.imageshack.us/img102/4448/dsc07701rz4.jpg
& closeup
http://img102.imageshack.us/img102/4250/dsc07729lp9.jpg
Thanks for any assistance. Kirk
05-11-2008, 08:31 AM #2
Re: Siding Type?
Hardbaord siding--
This siding is at or has exceeded it's life expectancy and is deteriorated to the point of needing immediate replacement. My recommendation is for a qualified siding contractor who specializes in siding replacement provide replacement costs prior to the expiration of all buyer options.
Rich
05-11-2008, 09:10 AM #3
Re: Siding Type?
My assessment exactly. And, coincidentally, Hardboard Siding is what I put for it
. Go me!
05-12-2008, 05:28 AM #4
Re: Siding Type?
This is hardboard siding and I agree with the other assessments.
05-28-2008, 04:43 AM #5
Siding Type Revisited
I come upon this from time to time. My guess is that it is a form of asphalt as it looks and feels like asphalt roof shingle material, but is used on houses sometimes. This is the first time that I've noticed it has layers behind it. So, now I'm wondering if there's more to it. Any ideas?
Here is the rear of the house in all its asphaltial glory:
And here is the close-up:
ImageShack - Hosting :: dsc08242ii4.jpg
As always, I appreciate all your help. Kirk
05-28-2008, 05:57 AM #6
Re: Siding Type?
Is it brown and crumbly? This would be the masonite siding. If it is actually grey paper like material ( resembling cardboard packing dividers ), the only place I've personally seen this used is on Wausau homes in the mid seventies. Might be able too contact them for more info. Interrestingly, they also used material made from this for the soffits and in place of drywall.
05-28-2008, 06:55 AM #7
Re: Siding Type?
Wow Kirk. That's like a blast from my past back in the northeast. There was a lot of that on the lower end houses in PA. I wasn't a home inspector back then, but I'm pretty sure it was just an asphalt shingle designed for vertical siding. I don't know what they layered behind it, probably just tar paper. I think the majority of them have been covered with vinyl or aluminum siding by now.
05-28-2008, 07:00 AM #8
Re: Siding Type?
The material in the second detail is "asphalt impregnated celotex board" AKA "rolled asphalt brick siding", very common in my area.
A page on this material:
National Register of Historic Places | Historic Properties | Historic Preservation of Arkansas landmarks and Main Street Arkansas through programs & grants
It's really not such bad stuff, it holds paint well and as each panel (about 24x36") is held on with 4-6 nails it usually comes off without additional damage to the underlying surface.
Here's how I report it:
Observation: (FYI ) Portions of this building are sided with asphalt impregnated celotex board (also called "rolled asphalt brick siding") which was often sold under the brand names of Insulbrick, Inselstone or Inselwood. This siding consists of a granular asphalt exterior layer (much like the surface of a roofing shingle) bonded to a fibrous core. This siding is subject to damage when struck by hard objects and tends to fray and/or crack at exposed edges and corners. Eventually, sections of the surface coating may detach from the fibrous base. Replacement siding is no longer available. The panels were typically nailed to the underlying surface with 4-6 nails per panel, and can usually be removed with little additional damage to the surface below. For additional information see: National Register of Historic Places | Historic Properties | Historic Preservation of Arkansas landmarks and Main Street Arkansas through programs & grants .
Feel free to lift any of that you find useful.
05-28-2008, 07:17 AM #9
Re: Siding Type?
My thoughts exactly when I saw it "Wow Kirk. That's like a blast from my past".
And New York state as well.There was a lot of that on the lower end houses in PA.
I was just a kid, but I remember that stuff on many houses.I wasn't a home inspector back then,
Yep.but I'm pretty sure it was just an asphalt shingle designed for vertical siding.
Or, as in the second photo, asbestos cement shingles behind it.I don't know what they layered behind it, probably just tar paper.
05-28-2008, 07:56 AM #10
Re: Siding Type?
OK, now I see a picture. Yep, definately the fake brick / asphalt material. Still see some locally. My biggest concern would be the flamability issue.
05-28-2008, 11:07 AM #11
Re: Siding Type?
The material behind the asphalt seems papery (cardboard or layered paper). The asphalt is definately tacked over wood shingles. I would say ... "This siding consists of a granular asphalt exterior layer (much like the surface of a roofing shingle) bonded to a fibrous core" ... is the best description. Thank you Michael and everyone for your detailed responses. Kirk
