    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    Default Electrician Moonlighting as a Plumber
    Electrician Moonlighting as a Plumber...
    (attic installation and support of sanitary vent piping)
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Electrician Moonlighting as a Plumber
    It looks like somebody forgot to go back and finish the job.
    This new Construction is deemed Finished, Completed and Approved by Municipal Inspector.....
    James Duffin Guest
    Amazing.......
    I'm not surprised it was approved. They don't want to climb into an attic. It looks like the water has to run uphill to drain(?)
    I assume you got enough light on that to look behind that...
    Michael Greenwalt's Avatar
    Michael Greenwalt Guest
    Nah, those are high end copper support connectors. Consider it an upgrade!
    Quote Originally Posted by Michael Greenwalt View Post
    Had not looked at it that way before ... those "copper support connectors" are even insulated and covered too ... does that make it the super duper high tech upgrade?
