    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cutting concrete wall
    What if any are the reprecautions of this half assed attempt to gain access to an area of the crawl space to install a vapor retarder.
    Default Re: Cutting concrete wall
    Photos might help
    Repre- what?
    Other than ruining a manicure and a Good claw hammer ?
    I don't see any repercussions other than the exposed re bar that could rust.
    It's late and I am currently on a third grade spelling level.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Looks like they lost heart in the project. i have cut bigger holes in foundation then that with no problems. but you may want tp make a note about it.
    Life is short have some fun and a good Cigar.
    Well ... that steel rebar needs to have a specified amount of concrete cover to help protect it from moisture and rusting out, and that's just a 'non-structural' issue.
    I suspect that if it had been done properly, it might have been okay. As it is though, there is the potential that the foundation wall as been weakened some (maybe not much).
    The only way to answer the question of "weakened some (maybe not much)" is to have a structural engineer "design appropriate repairs", which, yes, includes no repair "if the structural engineer deems no repair is needed". Either way, though, your client ends up with a signed and sealed engineering letter for their records and for when they go to sell.
    "Life is short have some fun and a good Cigar."
    Avoid the cigar and life might no be so short ... and it would be a lot more fun too.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Is that a quote from George Burns?
    Oct 2007
    Arizona
    Andy Dufresne: Get busy living, or get busy dying.
    Now this is a HOLE. And? HEHEEHAW
