Thread: Flexible P Trap
    Stephen G Sheldon's Avatar
    Stephen G Sheldon Guest
    Default Flexible P Trap
    Never seen this before. Is it legal and should it be called out?
    Texas
    Default Re: Flexible P Trap
    If it has a "seal" from IAPMO or UPC yes! But I don't think this one has any kind of approval except "jack-leg"!
    Write it up!!!
    Thanks. Didn't look right to me.
    Texas
    All fittings that are used in plumbing must have some type of testing agencies approval. The UPC (Uniform Plumbing Code) which looks like a warrior shield with the letters UPC within that shield is accepted. The ones I see in our area are the IAPMO (International Association of Plumbing and Mechanical Officials) and UPC that approve the fittings. There are others but the fitting will have some sort of approval from an agency.
    Quote Originally Posted by Stephen G Sheldon View Post
    That, like the flexible tail pieces, are "legal" in that they are allowed to be 'made', 'sold', and 'bought', however, ... they are "illegal" as soon as you install one.
    Tony Watson's Avatar
    Tony Watson Guest
    Might be legal..... but not installed properly.
    Quote Originally Posted by Tony Watson View Post
    Tony,
    The only 'proper way' to install that is to leave it in the box it came in, set it up on the shelf in your workshop, and let that be a reminder that 'we all buy stupid things' now and then, and that those 'stupid things' are just someones way of getting some money for nothing ... and it worked ... again.
    Bethlehem,Pa.
    Looks like a Dollar Store special.
