Results 1 to 15 of 15
    Fredrick O'Leary's Avatar
    Fredrick O'Leary Guest
    Smile Intro & Question
    Hello to all;
    I am not an Inspector, but I find the information in this forum very interesting and useful. I am a home owner and a "do-it-yourself" type individual. I only do things that I research, understand, and feel that I am capable of doing. I try to do thing the correct way.
    I was reading the post on drip edge flashing for roofing because every time it rains the water does not go into my gutters, but runs between the house and the gutter. This is creating a great deal of damage to my foundation and a recently installed door that all the stain is peeling off at the bottom - not the top.
    Would installing a gutter apron/drip edge flashing solve this problem?
    Fred
    Default Re: Intro & Question
    You would get more useful help if you post some pictures........
    Ron Bibler's Avatar
    Ron Bibler Guest
    Quote Originally Posted by Fredrick O'Leary View Post
    Hello to all;
    Fred
    Hello an wellcome to the board. to start moisture condition is the main thing that all homes need to be protected from. anything you do to keep the water off is good.
    It would be smart to get in contact with a local home inspector in your area and have him do a limited inspection and consultation on your home. If its been more then 5 years you should have him do a complete inspection on your home. Money well spent.
    You should be able to find a good inspector on this board for your areas.
    Ron Bibler
    Excellence Exterminating and Thermal Imaging
    Calif. Branch #3 Build Inspection Co.
    Thumbs up Re: Intro & Question
    Ron,
    Thanks for the advise and recommendation. I believe I will take you up on that advise. I am assuming that a local inspector would be able to provide input on other areas in addition to my gutter problem.
    Thanks,
    Fred
    Lightbulb Re: Intro & Question
    Brandon,
    What type of pictures are you suggesting??
    I am new at this and posting anything is a challenge.
    Fred
    Fred,
    I don't think you need to hire an inspector to tell you that water isn't making it into the gutters. You already know that.
    Go ahead and hire one if you want a thorough evaluation of the house. If you want the water to run all the way into the gutters, there are many products designed to bridge the gap between properly installed gutters and the roof line.
    Some examples:
    This Old House
    Protective drip edge
    Brandon,
    Fred
    Fredrick O'Leary
    Boy if that isn't a good Ole Irish name from Mass I don't know what is.
    Brandon,
    Fred
    Resized ( I use The Free version of Bomes Image Resizer . )
    Type in your comment.
    Scroll down to The Upload Photos box below.
    Click browse & choose your Photo.
    Click upload.
    Close that Browse window.
    Submit Reply or Preview Post.
    Dom,
    Thanks for the information. The examples were very helpful.
    I am working on my next steps.
    Fred
    Fred,
    Some examples:
    This Old House
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Wink Re: Intro & Question
    Hi Fredrick,
    There is usually a very simple fix to this problem, as I have had this same complaint from many a customer (I do remodeling and maintenance repairs also).
    It is best to do this while you are having a light rain to immediately see if you need to address a certain area.
    I usually do this from the roof but if the pitch is too great it can be done by moving a ladder along the gutters.
    You ready... All you have to do is bend the drip edge out away from the house. A lot of roofers place it too close to the fascia which allows the water to run behind the gutter. By bending the drip edge you allow it to do its job of directing the water into the gutter. You will have to experiment to see how much to bend it as it usually doesn't take much. Please wear a pair of good gloves so you don't cut your hand.
    This procedure has worked many many times for me, in fact I have to go do one in the next couple weeks on a customers house that was just roofed last year.
    Regards, Lee
    Quote Originally Posted by Lee Nettnin View Post
    Hi Fredrick,
    Regards, Lee
    What happened to the 1x2 that should be behind it to make it stand out from the fascia.
    Lee Nettnin Guest
    Ted,
    It is NOT a building practice to include that in my region. Not saying it's right, just a very rare occurrence.
    Lee
    Hi Lee,
    I actually got my ladder out and took a closer look at the flashing and gutter. It is flush with the fascia which allow the water to run straight down. Ted's comment about the 1X2 is right on. If they had put one there it would work correctly.
    I think that bending the drip edge out will do the trick. Thanks for the advice. It makes the most sense and is the most cost effective solution.
    Fred
    Hi Fredrick,
    Regards, Lee
    Ron Bibler's Avatar
    Ron Bibler Guest
    Hi Lee,
    Fred
    Well then I think that lunch is in order. Say fredrick. do you a $ 5 sopt for a cut of coffee? L.O.L.
    Brandon,
    Sorry Fredrick,
    Just back on the board from a weekend. I like to see pictures to help determine the cause of the problem. Not everyone out there explains things precisely. Pictures are much easier to understand than words sometimes.
    Anyway's, I'm glad it sounds like you got it figured out.........
