Results 1 to 16 of 16
09-19-2008, 08:29 PM #1
Is the clearance rule 10 feet here?
I was under the assumption the clearance is 10 feet for this.
Similar Threads:Last edited by Marc M; 01-18-2010 at 09:04 PM.
09-19-2008, 08:53 PM #2
Re: Is the clearance rule 10 feet here?
Is that a "swamp" cooler?
09-19-2008, 08:58 PM #3
Indeed it is.
09-20-2008, 06:08 AM #4
B vent manufacturer Hart & Cooley installation instructions say 8 foot clearance reqired to a vertical wall. If the there is less than the 8 feet clearance, the vent must be raised 2 feet above the structure.
I don't know, does that qualify as a wall or structure?
09-20-2008, 01:23 PM #5
That is a major air intake for the house, and you definitely don't want that vent located right next to it like that.
09-20-2008, 01:40 PM #6
Jim, It's an air conditioning unit, not a "major air intake".
09-20-2008, 02:22 PM #7
Yep, it is a MAJOR fresh air intake, NOT an air conditioning unit.
Swamp cooler = evaporative cooler, not a refrigerated air unit.
You won't see these in more humid parts of the country, since it adds humidity to the air in order to lower the temperature.
The louvered panels you see in the picture are air inlet grills that usually have a wet straw mat behind it. Air is drawn through the mat and directly into the house displacing the warm air with cooler air.
Right, Jim (the other Jim
09-20-2008, 02:26 PM #8
09-20-2008, 03:08 PM #9
It's a southwest thing. They are all over out here, not so much in NJ.
09-20-2008, 04:26 PM #10
Yea...EVERYTHING is weird in california!
09-20-2008, 05:24 PM #11
What kink of crazy world do you all live in; making the air MOVE humid.What happened to my smiley face?
09-20-2008, 06:04 PM #12
Swamp Cooler (never seen one myself, but heard of them).
Is that why there is a hose bibb there?
Two things:
1) Yes, *I* would treat that as a "wall" next to the B vent, meaning it needs to be 8 feet away or 2 feet above it.
2) Being as that is a "swamp cooler", get it away from the air intake.
Nothing is flashed properly there either.
09-20-2008, 08:16 PM #13
Thats funny. Jerry, you make it sound like big foot. But I suppose you wouldnt have ever seen one in FLA, no shortage of humidity there.
09-20-2008, 08:18 PM #14
09-21-2008, 11:59 AM #15
09-22-2008, 11:03 AM #16
B-vent would need to be 2 ft taller than the Swamp Thing and it needs a storm collar. While they're at it, they can remove all that combustible plastic roof cement from the B-vent.
