Results 1 to 11 of 11
		Thread: Gas Meter Location
	10-25-2008, 09:12 AM #1 Gas Meter Location Gas Meter LocationGas meter in living room enclosed in a wood box. Exterior through wall vent (3/4" inch galvanized pipe). Meter viewable through cutout. No main cutoff access unless out in street somewhere. Original house built in 1904. Addition ca. 1960. And yes, that is a 14" floor height differential without a safety rail or steps behind the meter box.
 Would a meter installation like this be allowed even in the 60's?
 Similar Threads:The above statements are expressed solely as my opinion and in all probability will conflict with someone else's.
 Stu, Fredericksburg VA
	10-25-2008, 09:40 AM #2 Re: Gas Meter Location Re: Gas Meter LocationNot even in the 1860's !!!
	10-25-2008, 10:30 AM #3 Re: Gas Meter Location Re: Gas Meter LocationI would assume that the meter was outside of the structure originally, but the exterior wall has been opened up for a room addition. That probably explains the step down of the floor.
 Gas meter inside the structure? NO can do. Well, they did do it but its wrong.
	10-25-2008, 10:56 AM #4 Re: Gas Meter Location Re: Gas Meter LocationGoes along with my thoughts too.
 Enclosed carport into a room, removed part of wall, and ... Dang! Billy Bob, what are we going to do with this here gas meter? ... Well, thar ain't no permit, so we can't call the gas company, ummm, we'll just box 'er in and make an opening to read it from the outside - if the gas company does not complain, we'll be home free.
 Yeah, that's a ... YIKES!
	10-25-2008, 10:59 AM #5 Re: Gas Meter Location Re: Gas Meter LocationI grew up in a home that was built in the early 50s.
 The gas meter was inside in the basement.
 Reading Your Natural Gas Meter
 Reading your own meter is one of the easiest ways to ensure that you are paying only for the natural gas you use. It is simple to do, and most companies will let you submit your meter reading over the phone or through the Internet.
 Most natural gas companies attempt to obtain an actual meter reading every other month. From time to time, the natural gas company may not be able to get an actual reading from your meter. If your meter is inside your home (usually in the basement), behind a locked gate, or guarded by the family dog, you may see estimated readings on your natural gas bill. To get an estimated usage, the company uses a sophisticated formula that takes many factors, like the outside temperature, into account. For most customers, the difference between the estimated and actual usage is adjusted when the meter is read by the natural gas company the following month. However, for customers that have inaccessible meters, their bills may be estimated for several months in a row.
	10-27-2008, 07:07 AM #6 Re: Gas Meter Location Re: Gas Meter LocationThe gas meter inside the house is very typical up here in older homes. Basement, hallway, stairwell are typical. The in-ability to readily turn-off I would write up as a hazard. The particular location I would recommend to be changed also.
	10-27-2008, 07:34 AM #7 Re: Gas Meter Location Re: Gas Meter LocationIt is my understanding that the regulators, which are at the meter, are not allowed to be within 3 feet of a building opening. Putting the regulator directly inside seems to be much more absurd then being outside within 3 feet of a building opening.
 If the gas meter is in the house, I would presume that the regulator was also. THAT (the regulator) is not allowed, as far as I understand.
 Hopefully Bob H. will rely.
	10-27-2008, 07:52 AM #8 Re: Gas Meter Location Re: Gas Meter LocationHaving a natural gas meter beneath a home in California is a bad idea. If the home is located near one of the major seismic faults it’s a terrible idea. When inspecting older homes where I found a gas meter located within the crawl space I always recommended my clients request the local utility company, usually the PG&E, (Pacific Gas & Electric) relocate it to an exterior location.
 I’ve attached a schematic published by the PG&E regarding clearances, which may be handy for some of our left coast inspectors?
	10-27-2008, 09:08 AM #9 Re: Gas Meter Location
		The above statements are expressed solely as my opinion and in all probability will conflict with someone else's. Re: Gas Meter Location
	10-27-2008, 09:36 AM #10 Re: Gas Meter Location Re: Gas Meter LocationWhat some are not considering is that the requirement is for the meter to be located in a ventilated area or that the relief port of the regulator can be piped to a ventilated area.
 I'm not saying that the pictured item is OK but that are ways to make it so.
 I see no harm in raising it as a concern and to having the local gas supplier provide some guidance on the matter.
	10-27-2008, 09:52 AM #11 Re: Gas Meter Location Re: Gas Meter LocationLooks like a home made bomb waiting to go off. I can only imagine if a slight leak occured in that box and filled it with gas and a spark were to happen anywhere close by.
 "Well, that is where my addition and home use to be"
