    Ron Bibler's Avatar
    Ron Bibler Guest
    Default 3 taps Cutler Hammer
    Why would they have 3 taps on the breaker?
    Cutler-Hammer Type CHAF - One Pole Arc Fault. 15 amp.
    Default Re: 3 taps Cutler Hammer
    Not sure what you are referring to as taps, but AFCI breakers, like GFCI breakers, have a terminal to which the hot conductors goes, a terminal to which the neutral conductor goes, and a white pigtail which goes to the neutral terminal bar.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Jerry they have 3 white wires in the lower back of this breaker?
    and 1 Black in the breaker?
    See if this diagram make sense.
    From this site Arc Fault Circuit Interrupteurs AFCI
    Ron,
    From the photo, there are two AFCI breakers side-by-side, I think the "3rd" white wire is actually to the other AFCI breaker. If not, that AFCI breaker is missing its 2nd white wire.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Thanks Jerry. its was hard to see back behind everything and did not want to stick my hand back in there. I have other minor issue with this panel. will let sparky look at it.
