Results 1 to 4 of 4
    Default main breaker cu/al
    Spliced one leg and not the other. So ... I guess they spliced copper and aluminum together. Nice.
    Default Re: main breaker cu/al
    As long as the breaker can accept the larger AL conductor I don't see what the issue would be. Split bolts and polaris type connections can handle a combination of conductor types as can breakers
    John,
    Is that the main breaker? If so, it was back-fed and needed to be secured in place on the other end.
    Also, there are other taped-up wires there ... why are they taped-up? Insulation bad?
    Have any other photos of that panel?
    Jerry - That is the main. And it is backfed.
    This property had so many electrical problems it was mind boggling. Someone who clearly didn't have a clue did tons of things like:
    using #12 to wire a 220 receptacle with an electric range plugged into it.
    Fire hazards galore.
