Results 1 to 15 of 15
    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default un-identified object
    this was connected to the supply line of the adjacent dishwasher. Is it some sort of heater? i didnt see any power lines, but it does have a power symbol?
    Default Re: un-identified object
    I may be a flow control valve, similar to a Flood Stop. They may have disconnected the sensor wire, which is a low voltage wire connected to the valve. Notice the flow direction arrow.
    It appears to be made for a larger pipe, so I doubt it's for a dishwasher exclusively. The tubing goes from 3/8 to 1/2 to 3/4.
    It could also be one of those water magnets, used to "soften" water.
    Dom.
    The pipe on the tip of the flow direction arrow looks like drain pipe, not supply pipe.
    Also note the electrical lightning symbol further down that same side, that would seem to be the electrical connection point (with nothing being connected to it.
    Supplying in from the left is the dishwasher supply, which is full pressure; I suspect that the pipe leaving the unit is not designed for full pressure.
    What's that drain line looking hose coming up from the bottom toward the sink - the drain line?
    What is it? I don't know, but it looks like some type of solenoid being as it has a water inlet, a water outlet, and an electrical connection point (with nothing connected to it).
    Joshua Hardesty's Avatar
    Joshua Hardesty Guest
    It's the water supply for a dishwasher. I've installed some like that before, trying to remember the brand. Basically, it's got a female hose thread connection on that beast to supply the dishwasher. It's hard to tell with the flash reflecting off the metal like that, but there's a few transitions there to get it down to 3/8 OD supply tubing.
    Peter Drougas's Avatar
    Peter Drougas Guest
    Joshua,
    But what is it? Or rather, what does it do?
    ----- Forgot what I was going to post and deleting 'just looks bad'.
    I know 'this looks bad too', but what can I say?
    As we get older, three things happen. First our memory goes... and I forget the other two.
    Gunnar,
    Maybe I should have said "Oops, posting to wrong thread.", but, I wasn't ...
    Hi, my name is ... (looks down at name tag clipped on upside down so it can easily be read this way) ... I got! ... Jerry.
    Peter Taheny's Avatar
    Peter Taheny Guest
    Quote Originally Posted by Peter Drougas View Post
    Joshua,
    From the Meile manual
    From their manuals, it appears to be some kind of pressure/flow sensing device. It says the pressure must be between 4.5-145 psi to operate. (That's a hell of a range.)
    Peter,
    First, welcome to THE inspectors board.
    Second, thank you for that information, I presumed that the 'lightning bolt' represented a location for connecting wiring, only to be shown that it is only an 'orientation direction indicator'.
    Peter Taheny Guest
    Peter,
    Jerry
    I've been lurking around here for 8 or 9 years.
    Quote Originally Posted by Peter Taheny View Post
    Jerry
    (The "lightning bolt" should be above the "arrow" when the installation is complete.)
    Not installed per manufactures instructions!
    Don't have any idea of the consequence!
    Peter Drougas Guest
    So the Meile manual shows how it should be installed. There's still nothing about what it does. Does it heat the water flowing through it?
