Thread: Air handler question
01-25-2009, 09:40 AM #1
While inspection a air handler, I found a blue box attached to the end of the unit. It was labled UVAIRE, and was pluged into a nearby outlet. The box had a on and off switch on the bottom. There was also a wire running into the duct work, and a red light behind the grill right above the return filter. Has anyone seen this before?? and what is its purpose??
Thanks everyone
01-25-2009, 09:42 AM #2
Re: Air handler question
Ultraviolet light to cleanse bacteria from the air.
01-25-2009, 09:43 AM #3
01-25-2009, 09:50 AM #4
The only thing I know about these things, which I've posted before, is don't assume the thing is killing any microorganisms just because the light is on. My understanding is that the germicidal effectiveness goes down long before the light fails.
01-25-2009, 11:24 AM #5
01-25-2009, 06:50 PM #6
