Results 1 to 20 of 20
    La$ Vega$, Nevada
    Default Ammo in garbage disposal
    We've all seen bank 'repo' homes damaged by the occupants on their way out. How many have seen 'booby-trapped' homes? Here's something (see attached photo) to think about the next time your ready to throw the switch on the disposal unit...without first looking into the grinding chamber to see what's waiting inside! As if we all don't have enough to worry about...
    Glenn R. Curtis CMI
    La$ Vega$, Nevada
    Inspecting Nevada since 1982
    Default Re: Ammo in garbage disposal
    I've purchased flashlight batteries from CopQuest. Now I guess I need a bullet-proof vest?
    Quote Originally Posted by Glenn Curtis View Post
    Glenn: Jeeeeeez, I really never imagined that!
    I never think to look inside the grinding chamber before flipping the disposal switch. Insane.
    I know nothing about guns and bullets, not being a REAL MAN.
    What are the odds that thing is going to go off?
    John: Highly probable.
    Back in my crazy days, I used to throw live ammo in a fire (they pop and throw embers), and have seen someone throw live .22 rounds out of a moving car (they go off)
    It looks like rimfire ammo-- I would say the round going off is probable. If it is centerfire, I would say doubtful, but still possible.
    The chances of the round going off and actually causing any real harm...... unlikely.
    Either way, I wouldn't want to be the one turning on that disposer
    MaMa Mount's Avatar
    MaMa Mount Guest
    As kids we used to bang the shells with a hammer to get the gun powder out. Not once did they ever go off. You could turn on that disposer and i say nothing would happen but maybe jamb it up.
    All you need is for the primer on the base of the shell to get hit just right. But it wouldn't be like the bullet was fired out of a gun. In order for the bulle to be deadly, you need the pressure that's created when the bullet is driven through a small diameter barrel. In an open chamber like the disposal, you can't get that type of pressure.
    Kerry Nobbs's Avatar
    Kerry Nobbs Guest
    Kind of interesting that is for sure. 22 from the look of it. Find anything else around booby trapped?
    Brookville Ohio
    Wow,the only things I have found in repo's are broken keys in door knobs and trash,opened up my eyes,,,,,,Don
    Don Anderson
    Ron Bibler's Avatar
    Ron Bibler Guest
    That looks like it some one had hit the on switch
    Brandon Chew's Avatar
    Brandon Chew Guest
    Sounds like a job for the Mythbusters!
    Quote Originally Posted by don anderson View Post
    Plugging the drains and leaving the water on is real popular around here.
    Moisture Meter off the hook as High as 36 inches off the floor in the (use to be) Drywall.
    Brian Thomas's Avatar
    Brian Thomas Guest
    That reminds me of the "wet bandits" from the movie home alone
    Chandler, AZ
    That is crazy! Probably a criminal act.
    Yes, I've had my share of repo inspections. Never could figure out why someone would take a kitchen island, or put the toilet in the middle of the room. I sure do look carefully at ALL wiring and plumbing before switching them on. Now I will add checking the disposal.
    We don't get paid enough for that kind of risk!!
    Be careful out there! (isn't that what they said on "Hill Street Blue"?)
    Dave Hill
    Buyers & Sellers Property Inspections LLC
    WWW.BuyersSellersPi.Com
    Funny you say that Fritz (and Brandon for mentioning mythbusters). Ever since this thread started, I have been trying to locate an old, beat up disposer to try it out. If I ever get to it, I'll post the results...........
    Only if your not dead. If you never post again, we'll figure out the experiment.
    Brandon, If you only have 1 disposal, try the rimfire ammo last. I think it will go off but I don't think the centerfire will.
    Agreed.
    I'm all about calculated risks........ this one doesn't even have me worried. (plus, I won't be standing over it)
    Richard Moore's Avatar
    Richard Moore Guest
    Just be sure to get the whole thing on video for the annual Darwin awards. Darwin Awards: 2008 Darwin Awards
