Thread: Attic issues
    Sep 2007
    San Antonio TX
    Default Attic issues
    Default Re: Attic issues
    Most likely (no doubt in my mind) that the truss top chord is not designed for the weight placed on it. Engineer should evaluate. Do you know if the dimensional lumber was installed after the building was constructed?
    Sep 2007
    San Antonio TX
    Quote Originally Posted by Zibby Swieca View Post
    But what is dimensional lumber.
    He's referring to the standard 2X6, 2X8, etc. boards, as opposed to engineered trusses and such.
    ... as opposed to engineered trusses and such.
    Which are made of pieces of dimensional lumber.
    Mike Truss Guy's Avatar
    Mike Truss Guy Guest
    In non-snow load areas, especially prior to the adoption of higher design loading in IBC, it was customary to specify a toe-nailed connection for jack trusses up to about an 8' span. The jacks can be trusses or they can be conventional framing. You can not see the nails from the back side, you would need to see them from the front face. If there are nails then it was probably adequate for the code when it was built.
    It's a bit unusual to see 2x6 jack framing with 2x4 trusses, but there's nothing wrong with that. Also note that the flat 2x6 purlin laid on the top is also a customary practice for bracing the flat top chord.
    Have a great day.
