Thread: Need info
    Richard Roshak's Avatar
    Richard Roshak Guest
    Default Need info
    I need help to determine if a gas forced heating unit is installed correctly. Its a Comfortmaker model# GNI60A012AIN, serial#R920401796. Can this unit be installed horizontally?
    Rich
    Default Re: Need info
    Looking at the bottom of the data plate it says that it is approved for a horizontal flue pipe.
    Was it installed that way or was it coming out the top?
    Outside of that I would contact the manufacturer, they will know for sure.
    Good eye there, Scott.
    Rick
    It also says "(Forc)...ed Air Furnace For Indoor Installation Building"
    Higher up it states this again "For Indoor Installation At Minimum Clearance"
    Now, is an "attic" "indoor", or, by "indoor" do they mean 'in the thermal envelope"?
    I suspect they mean 'not outdoors', which could be in an attic, but, the way it is worded ...
    Does that bottom line mean for horizontal installation, or just for "(List)...ed For Single Pipe Horizontal Vent"?
    Jan 2009
    Tennessee
    The GNI series forced-air furnace is an induced draft, high efficieny model which can be installed in the upflow or horizontal position. It is approved for horizontal venting.
