    Default Bollard Attempt to Protect Condensing Unit
    Don't think that this bollard is going to be much protection.
    Default Re: Bollard Attempt to Protect Condensing Unit
    It might surprise you.
    That 'could have' (but we know this is unlikely) a #8 rebar in there.
    It might be "plastic" on the outside, but it ain't a gonna move on the inside!
    Not if there was a #8 rebar embedded in 4" concrete.
    imported_John Smith's Avatar
    imported_John Smith Guest
    Did you pee on the condensing unit? I see water around the outside of it on the concrete.
    It's also below the meter, right in the working space required for the meter.
    Richard Stanley's Avatar
    Richard Stanley Guest
    That pipe is for cell phone wiring only!
    That foam core pvc is not allowed for under ground use in some areas!!!
