    Rick Burkman's Avatar
    Rick Burkman Guest
    Default What is this called?
    All right, I should know the name of this dangling piece that should be sealing the base of this metal roof, but my mind is drawing a blank and I can't find it listed anywhere - so what is this hanging piece of foam really called and how is it normally attached?
    Default Re: What is this called?
    Roof edge weatherstripping requires proper attachment would be my terminology
    state of jefferson
    closure strip?
    Bird stop?
    Edge gasket.
    Usually closure strip, seal strip, or starter strip, although it may vary from manufacturer to manufacturer.
    You will have different ones along the ridge where the ridge overlaps the metal panels.
    Corrugated Metal Roofing, Siding Material, Metal Siding Systems
    See second last photo.
    Brian and Jerry win for most correct answer.
    Frank Suchodolski's Avatar
    Frank Suchodolski Guest
    Foam Closures, they can be self adhered or, in this case, should have been installed into a bead of caulking. (Poly-urethane, not silicone)
