Results 1 to 4 of 4
Thread: Trusses
    John Stephenson's Avatar
    John Stephenson Guest
    Default Trusses
    Default Re: Trusses
    Quote Originally Posted by John Stephenson View Post
    On exterior wall , you'll see the bottom chord of the truss rafters.
    The bottom chord of the truss rafters are nailed to the ceiling rafters.
    1-Is this acceptable?
    2-Shouldn't they use joist hangers? Only on one rafter did they use the joist hanger where the bottom cord was connected to the ceiling joist.
    I'm confused.
    There are "trusses".
    There are "rafters".
    There are "ceiling joists".
    There are no "truss rafters".
    There are no "ceiling joists" with trusses.
    Trusses have a top chord, a bottom chord, diagonals and verticals.
    Are you referring to the top chords and the bottom chords?
    Corpus Christi, TX
    Default Re: Trusses
    See above.
    Also, send whatever pictures you have. Do you have any distance shots?
    - Paul Fix
    Default Re: Trusses
    John,
    Those are all "trusses", which have top chords (what the roof sheathing goes on) and bottom chords (what the ceiling attaches to).
    Are truss hangers required? Depends.
    Sometimes yes and sometimes no. If specified by the truss engineer, yes.
    Is it "better" to use hangers? Yes. Is it "required", not to my knowledge, depends on the truss engineering.
