Results 1 to 21 of 21
		Thread: PVC to ABS
	07-26-2009, 06:44 AM #1
	07-26-2009, 08:30 AM #2
 Re: PVC to ABS
		No not if it is sound and the proper glue used.
	07-26-2009, 09:08 AM #3
	07-26-2009, 10:13 AM #4
 Re: PVC to ABS
		A single transition fitting between different types of systems and the correct solvent is what the AHJs accept here.
	07-26-2009, 10:50 AM #5
 Re: PVC to ABS
		There is no correct solvent for joining the two different materials together.The solvent for PVC is to aggressive for ABS and the ABS stuff does not solvent weld the PVC properly. There are solvents that say they will join the two differnt pasltics togather but they do not meet the ASTM standards.
A proper transition is a a PVC to no-hub transition fitting, a no-hub coupling then a ABS no-hub transition fitting. Or You could use PVC male/female fitting threaded into a ABS male/female fittings.
	07-26-2009, 11:00 AM #6
 Re: PVC to ABS
		Acrylonitrite Butadiene Styrene (ABS) Pipe
ASTM D 2661-1997A, ASTM F 628-1997, CSA B181.1 in B1800-1999
Joints
ASTM D 2235-1996,a CSA B602-1999
Solvent Cement
ASTM D 2235-1996a, CSA B181.1 in B1800-1999
Polyvinyl Chloride (PVC) Pipe and Fittings
ASTM D 2665-1996, ASTM D 2949-1987, CSA B137.2-1999 in B137, CSA B181.2-1999 in B137
Solvent Cement
ASTM D 2564-1996
	07-26-2009, 11:24 AM #7
	07-26-2009, 11:24 AM #8
 Re: PVC to ABS
	07-26-2009, 11:37 AM #9
 Re: PVC to ABS
It is my understanding that those are "adapters" for "adapting" from slip to threaded and not "transition" fittings to "transition" from one material to another.
We had a thread on this quite some time ago, maybe a year ago or so, with links to "transition" fittings.
This was not the link, I thought I had saved the other link but cannot find it, however this shows the "transition" fittings: http://www.spears.com/prod_brochures...7_0208_web.pdf
You could transition from PVC to metal to ABS (or whatever transition fittings you used allowed for).
	07-26-2009, 01:29 PM #10
	07-26-2009, 01:52 PM #11
	07-26-2009, 02:05 PM #12
	07-26-2009, 03:16 PM #13
 Re: PVC to ABS
		IPS Weld-On is also green. I don't know about the rest.
	07-26-2009, 04:15 PM #14
 Re: PVC to ABS
		I am sorry the above is from the Illinois code book as approved types of pipe , fittings and solvent. I should resist posting while having a migraine.So anyways, the ones you list do have an ASTM standard but is not listed in the Illinois plumbing code book as approved solvents. You will have to check to see if they are allowed in your local area as we all know all plumbing codes vary from state to state.
	07-26-2009, 05:23 PM #15
 Re: PVC to ABS
		Back to John's question. I've had a PVC pipe glued to ABS under my shower for about 16 years, and it hasn't leaked yet. I also haven't seen any leaking at other houses (yet). However, I haven't inspected thousands of houses either.
I usually tell them that the two type of pipe are not meant to be glued together, etc. I doubt anyone ever does much else with the information.
	07-27-2009, 05:28 AM #16
 Re: PVC to ABS
		JR: As is the case with much of what we report, I fear.I doubt anyone ever does much else with the information.
	07-27-2009, 07:22 AM #17
 Re: PVC to ABS
		So even if there is a solvent available to use that will glue the two types of pipe together, how can you tell from a visual perspective that it is?
	07-27-2009, 07:31 AM #18
	07-27-2009, 07:41 AM #19
 Re: PVC to ABS
		Thanks A.D. for the reply!
	08-08-2009, 03:04 PM #20
 Re: PVC to ABS
	08-08-2009, 04:06 PM #21
 Re: PVC to ABS
		I know what you mean. They get a credit at closing for all the life-threatening hazards you have disclosed to them, and then they spend the money on kitchen cabinets.
It's like when you have a fender-bender that's the other guy's fault. You get a check from the insurance company. You stand there and look at the check, and look at the dent, and look at the check, and say to yourself, Heck, I can live with that dent! And you cash the check and get a flat screen tv.
