Thread: Toilet questions - - no kidding!
06-18-2007, 06:29 PM #1
Similar Threads:Last edited by dan orourke; 01-01-2008 at 01:27 PM.
06-18-2007, 07:44 PM #2
Re: Toilet questions - - no kidding!
I'm hunting elephants (to paraphrase Jack) not mice. Those are mice.
06-18-2007, 09:14 PM #3
Note the deficiencies that effect the operation of the plumbing fixture.
Surface corrosion on the float rod will not cause the Toilet to be inoperable.
It may be indicative of a condition worth monitoring (Well Water Conditioning) but not a condition warranting repair without some other deficiency being present
06-19-2007, 04:19 AM #4
I probably wouldn't write up either one - unless the house was brand new, or the toilet wasn't flushing properly.
06-19-2007, 05:31 AM #5
I would write up the leak at that fill valve. That is one that you will most certainly see after only a couple years old. That type is a piece of crap.
That leak becomes pressurized after a while and tends to run up-then-under the tank cover. Once that happens, the wall behind the tank becomes damaged.
Rich
06-19-2007, 05:43 AM #6
It's okay to shoot mice every once in a while, but baby mice?
When you start talking about individual components of, I think the report starts to lose value. I would call it out for the reasons RR stated. "The filler valve and float assembly is degraded from normal wear and should be replaced."
- Paul Fix
07-20-2007, 08:27 AM #7
The Webster on-line dictionary says this
Main Entry: ball cock
Function: noun
: an automatic valve whose opening and closing are controlled by a hollow float at the end of a lever
I would suspect a "Fill Valve" would be a more precise term, but ball cock is a pretty universal term generally understood by the public.
The plumber is likely just busting your chops since you are a lowly HI. Technically he may be correct, but I'll bet he knew where to look when you called it that.
08-03-2007, 05:05 PM #8
08-04-2007, 05:42 PM #9
Dan,
Just curious. Was house built in ~ 2002?
08-04-2007, 07:12 PM #10
Looks like somebody needs some potty training.
Bruce Breedlove
www.avaloninspection.com
The thing that it is pointing at is a water closet tank fill valve. Sorry, I could not pass it up.
