Thread: Trap question
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Trap question
    In addition to the missing vent, what is the min lenght requirement for the line behind the trap, preventing it from being an S trap.
    Randy Cooper's Avatar
    Randy Cooper Guest
    Default Re: Trap question
    Are you referring to the trap arm length?
    Check out the electrical receptacle on its back; the NEC prohibits receptacles from facing up in wet locations.
    Snagged this off this site ( can't remember who posted it.)
    Yes the trap arm. And I called out the outlet, although the electricians response was the area is not wet.
    Quote Originally Posted by Randy Cooper View Post
    They do?
    The NEC prohibits receptacles from facing up in kitchen and bathroom countertops, besides, that is not a "wet location".
    The NEC allows FLOOR receptacle to face up. Every seen anyone MOP a floor? I have.
    In addition to the missing vent, what is the min length requirement for the line behind the trap, preventing it from being an S trap.
    "preventing it from being an S trap"
    The only thing which will prevent it from being an 'S' trap is a vent.
    As I recall, though, there is a minimum trap arm length of 2 times the diameter of the pipe. That would be from the trap weir to the vent.
    Thanks Jerry for answering the question.
    Randy Cooper Guest
    They do?
    Yes Jerry,
    The NEC does prohibit recepticals from facing up in a wet location, I think I said that. I never called the space under a lav a wet location. I said "check out that receptical on its back" inferring a judgment call. Sorry for any confusion. As far as mopping floors, a floor receptical box is listed for that use. A 4x4 steel box I doubt, would be listed at all; especaily in that location. Again a judgment call. Besides, our Electrical Specialist said: "no way Jose" and his name is Jose too!
