    Default pipes in hvac return
    What do ya'll make of this? Pipes passing through return air.
    Montreal, QC, Canada
    Default Re: pipes in hvac return
    I know electrical wires thru an HVAC return is ok.
    never ran thru that situation before.
    I am thinking that depending on the use of the pipe and type of material I would not recommend it.
    i.e. hot or cold copper pipe runnin in duct. potential condensation in with the air return to furnace and then being sent thru the house.
    As well as temperature of the portion of the pipe running thru the duct different temp than rest of pipe. What does that do to the service life of the pipe?
    As well as needing to seal up all those holes !!!
    Real mess - just go around it i say.
    Quote Originally Posted by Joe Laurieri View Post
    Typically not okay. There are limitations on electrical conductors running through return air ducts and plenums.
    I agree, just go around, the only way to know if the potential problems exist is to take the duct apart, in which case the pipes may as well be re-routed around the duct.
    Now, a gas like or a DWV line through a return duct - that is a definite no-no.
    Jack Murdock's Avatar
    Jack Murdock Guest
    Is it a duct or a plenum? It looks like copper water or heat lines and a black steel gas line. There is nothing preventing gas lines through a plenum unless its a local AHJ distinction...
    Quote Originally Posted by Jack Murdock View Post
    It's a return duct. The black gas line isn't penetrating into the duct.
    Jack Murdock Guest
    John,
    Its OK to run gas water or electrical in a plenum just not through ductwork
    jack
