Thread: 1 inch clearance to combustibles
09-03-2009, 03:57 PM #1
Should I put this in the inspection report?
09-03-2009, 05:40 PM #2
Re: 1 inch clearance to combustibles
That and the improperly connected single wall connector, and that single wall connector requires 6" clearance.
09-04-2009, 04:13 AM #3
And the improper use of foil tape on the flue pipe.
09-04-2009, 06:49 AM #4
In picture one does anyone know how the water heater exhaust vent should be correctly connected to the furnace exhaust vent?
09-04-2009, 08:13 AM #5
Ryan: preferred practice is to have the water heater connected to the flue using a "Y" fitting to facilitate draft. Nature and physics don't like right angles.
09-04-2009, 12:04 PM #6
Really, you're not required to provide (and should not provide) a fix, repair or recommendation regarding how something is done or its repair (even if you're an expert in that feild). Just noting the condition in your report and why it is a deficiency and a reference to the properly qualified individuals who are licensed or certified to do the repairs. Note that if you prescribe a fix and are wrong, even a little, the client can come back to you legally.
