Results 66 to 94 of 94
Thread: Galvanized pipe
01-31-2010, 09:41 AM #66
Re: Galvanized pipe
KR: You do not need to reiterate my posts for me. Memorize them for your own edification, if you like.
At the risk of repeating myself again and again and again for the lowest common denominator on this forum, I did not state at any time that the product is inherently defective. No matter how you try to stretch the facts to fit your ill-conceived opinion, you simply cannot illustrate this. I know it is irritating for you to have put yourself in this position, and yet, there you are.
Now to your current (and cloying) questions: The wording of the question is nebulous. I am not sure what you mean by "bad". If by that term you mean inherently defective, then I have already stated that the jury in my mind is out. That means I have not made that decision yet. If by "bad" you mean evil or sinful, I do not believe in those concepts, and so the answer would be no.
If by "bad" you mean not achieving an adequate standard, I would have to agree. It is my personal and professional opinion that the piping and its manufacturer's installation instructions are inseparable. Since I deem the instructions to be inadequate, I necessarily believe the piping to be so.
If you mean by "bad" injurious in effect or detrimental, then under certain circumstances I would agree. I have seen both persons and property damaged by the installation of this product in strict accordance with its manufacturer's installation instructions.
This product has only been on the market for about 10 years. That is a relative newcomer for building materials. The manufacturers, in my opinion, are not addressing some of the issues they need to be addressing to insure the safe installation of this dubiously safe product. In my opinion it is glorified flexible appliance connector material.
As for CSST's performance during a lightning strike, I submit this for your perusal:
01-31-2010, 09:51 AM #67
Re: Galvanized pipe
ST: Weak points include, but are not limited to:
(1) Lack of bonding at the manifold.
(2) Inadequate support of piping in attics and crawl spaces.
(3) Installing the piping in harm's way. This includes where it can be struck by nails and other fasteners, laid across attic service flooring, et al.
(4) Inadequate support of shut-off valves.
And the above is for new construction only. In remodeling the problems increase exponentially. I have yet to see a gas line properly installed with striker plates where they are needed in an existing home. Even the builders are guilty of this. The scenario: the homeowner buys an inventory (completed) house which does not have a gas outlet for a gas cooktop in the kitchen. The plumber installs one using CSST, but does not install striker plates where the tubing enters the top plate or passes through fireblocks.
01-31-2010, 10:06 AM #68
Re: Galvanized pipe
I understand your points. But my question is; if you inspected... lets say 10 houses plumbed with csst, how many of the 10 would you expect to find at least one installation flaw.
My point is, even if 90% of a particular installation is protected, taking Murphy's Law into consideration, one or two unprotected areas are a gamble.
01-31-2010, 10:38 AM #69
01-31-2010, 10:52 AM #70
Re: Galvanized pipe
Did anyone answer "historically speaking" when galvanized pipe was introduced in residential construction?
01-31-2010, 11:08 AM #71
Re: Galvanized pipe
Yes John, more or less. The beginning posts addressed it... more or less.
In my opinion the house is plumbed with hubbed cast iron, galvanized, and lead.
Regarding the CSST, I would like to know about the workmanship some of the other fellows come accross. Especially work that is done "by others."
Is Aaron the only one finding these faults?
01-31-2010, 11:41 AM #72
Re: Galvanized pipe
IJS: Yes, it was answered early on before the jackals high-jacked the thread:
http://www.inspectionnews.net/home_i...tml#post117757
01-31-2010, 11:42 AM #73
Re: Galvanized pipe
01-31-2010, 01:37 PM #74
Re: Galvanized pipe
Steven it's been used here more then a decade and never heard of a problem with it. Pre-drywall Inspections I have noted on several occasions about protection in areas and proper support along it's length. But this is typical of most components of a home, people goof up while installing and that's why we have a job.
My pet peeve would be the installation to a gas pack unit on the exterior of a home. The run is susceptible to damage.
A.D do you not like appliance connectors also? You have your right to your opinion as we all have something we don't like. But quit twisting as most of us do when we get backed in a corner and say "uncle".
Oh by the way we used 16-D nails to support bundles of shingles in rows horizontally across the roof. The Mexicans would drive them in when done but I was cheap and pulled them. Ahhh to be young again!
01-31-2010, 02:02 PM #75
Re: Galvanized pipe
01-31-2010, 02:13 PM #76
Re: Galvanized pipe
Good article AD, thanks for posting it. I did not find a date of the paper, do you know when it was produced? I did not see any reference to the newer bonding requirements or reference to the lightening zone settlement so I am guessing the paper may have been prior to or concurrent with the litigation.
Although I am not quite as entrenched on the "CSST is crap" position as you, I do make mention of the past litigation and bonding issues and rarely see an installation that complies with the instructions on bonding, support, or bending circumference and can frequently be heard to utter "aw crap" upon observation of the yellow snakes in the attic.
01-31-2010, 06:51 PM #77
Re: Galvanized pipe
02-01-2010, 02:07 AM #78
Re: Galvanized pipe
I think this this thread has been lead away from galvanized pipe.
Nice car Charles !!!
See.
02-01-2010, 05:13 AM #79
Re: Galvanized pipe
02-01-2010, 05:20 AM #80
Re: Galvanized pipe
JL: Finally, an honest man, or at least one who is actually informed on the subject and looking for the usual problems.
It occurred to me yesterday that perhaps the reason many seem not be informed about the CSST lightning issue might be that lightning strike patterns are different in all parts of the country. I appears that the Left-Coasters, Westerners, and Yankees may not know much about lightning. Must be a Gulf Coast States thing . . .
Google Image Result for http://www.weather.gov/os/lightning/images/map.jpg
02-01-2010, 06:15 AM #81
Re: Galvanized pipe
We get plenty of lighting. Summer before last my 30' steel pole in the front yard was hit. Took out all my gfci outlets, big screen tv, small tv, and phones. Pissed me off that the manufactures did not factor in lighting strikes. ..........sorry AD.........just fanning the flames. ;-)
02-01-2010, 07:55 AM #82
Re: Galvanized pipe
Stu, Fredericksburg VA
02-01-2010, 08:13 AM #83
02-01-2010, 08:58 AM #84
Re: Galvanized pipe
MS: Yep, and to attach toeboards (temporary cleats), and to hold air hoses, et al.
02-01-2010, 09:40 AM #85
Re: Galvanized pipe
Ken are things that bad in your area that you are giving $100.00 off a home Inspection or free radon ?
I hope nobody in my area is beating down prices because they where to low from the get go.
02-01-2010, 10:40 AM #86
Re: Galvanized pipe
Csst has been usde in my area for aroud 10 yrs. Since i do few progress inspecitons what i see is usually in the basemet. Most of the installs are correct EXCEPT for the bonding, But the bonding requirments from some manaf. have been updated just late last year. See attached
02-01-2010, 11:58 AM #87
Re: Galvanized pipe
I'm not sure when bonding went into affect in our area, 08 I believe, but, I add it as a safety recommendation to all that don't have it, and explain why.
02-01-2010, 12:35 PM #88
Re: Galvanized pipe
Even the settlement from the CSST litigation was based on lightening strike zones. The more likely you were to get hit, the more money they would pay to help get it bonded.
I still wonder what effect the more robust bonding has had on lightening strike damage.
One other likely issue that would explain some of the differences in the lightening strike issues across the country is that houses with basements likely don't have copious amounts of CSST stuck up in the attic 30' in the air attached to appliances with metal b-vent lightening rods. Seems that if you had a basement and high efficiency heating appliances with Plastic vents hidden therein that the likelihood of lightening strike damage would be greatly reduced.
02-01-2010, 12:41 PM #89
Re: Galvanized pipe
02-01-2010, 01:04 PM #90
Re: Galvanized pipe
Most CSST around here is not for the furnance, it is for the Fireplace.
This puts it in the chase with b vent many times. As of present, I know of no acutal issues, fire or leaks, in the KC area from lightning.
Bonding is not enforced by any AHJ in the KC area that I am aware of,
I have had a standard bonding statement for 8-10 yrs,that discusses bonding the entire systems as needed.
Few inspectors (both HI and City) here understand or discusess this.
02-01-2010, 01:56 PM #91
Re: Galvanized pipe
Talk to a local fire marshal if you get a chance since no one but the fire department will every see the results of a failure of CSST as a result of lightening strikes and they will only see it if they specifically are looking for it in the ashes.
02-01-2010, 02:14 PM #92
02-01-2010, 03:05 PM #93
Re: Galvanized pipe
I believe he went to a magnet school
You guy's will whip up on a person in a minute I swear.........
02-01-2010, 08:37 PM #94
Re: Galvanized pipe
Bad in my area? I don't know about the other companies but it's Monday night, I did two inspections today and I'm booked solid through Saturday.
We're a national company. The company does this promotion every winter. It's nice because the inspectors get paid as if the client paid the full amount. Our radon technician is also paid their full amount. It's a great promotion as we get a ton of new referring agents with this offer and it gives more money to the inspectors in the slower winter months. Pretty much all of the promotions you'll see on our local website are national promotions which don't affect what the inspectors make.
But let's not hijack this thread any more than it already has been. Open a new one of send me a pm if you'd like to know more.
