Results 66 to 87 of 87
Thread: 12-2 with ground for multi wire
10-07-2011, 05:30 PM #66
Re: 12-2 with ground for multi wire
10-08-2011, 09:59 PM #67
10-08-2011, 10:01 PM #68
10-08-2011, 11:04 PM #69
have any of you worked on an electrical service from the service drop to a transformer to the main ditribution panel? Have you ever been ark flashed landing a ground to the neutral bar from following a persons work that never landed the ground to the XO at the transformer?
well I have, it was hot enough to blow an extra hole in the nuetral bar!
that is the potential of a flaoting neutral! and why I will always say the grounded condutor(nuetral) should not be the primary source to ground or the ground electrode. if the nuetral bar was grounded the nuetral would have been grounded and I wouldn't had metal drilled out of my eye.
never asume what you can't see.
NEC is minimul requirements, and when errors are found such as the alloy count on older aluminum wire, stab back/lock connectors producing higher resistance at contact points, or types of equipment that has been removed from production such as federal pacific panels( how many of those have you passed without telling the client they have been proven to not work properly, enough for the federal government to shut them down) these items or installation technics are never fixed or replaced, they are left for the owners to find out, some are found the hard way.
how many of you that inspect a home with alminum wire note an annual inspection on that service for maintaining the circuits and connections? thats in the NEC code book!
how many of you recomend a lightning arrester for metal roofs? they not required unless listed by state, BUT!!! they help reduce the conductive indifferance of a metal field to earth ground of the surrounding area.
speaking of lightning, homes on wells, do you check the tank (if metal) for ground? if the home is ran in a flex pvc/poly tube or none conductive material (except at the water heater for bond jumper if installed) what protects the plumbing from an electrical surge? copper has gotten expensive a lot of older homes have breaks in the copper lines from remodels and no bond jumper will be installed in that line.
HOW ABOUT THIS!! 1 in 7 families will be effected by an electrical malfunction this year, some will even lose loved ones from electricity. thats right over 450,000 homes will fave some form of an electrical malfuntion.
and I guarantee none will be from my work, can you guarantee none of your homes inspected by you haven't or won't have an electrical fire or malfuntion that will injur or kill a client?
so yes I will argue a 4 wire recept installed on an older service (Especially on an SE cable) would not provide proper protection of that circuit.
and yes a white wire landed under a breaker still needs to have an ELECTRICIAN ckeck those circuits.
10-08-2011, 11:47 PM #70
10-08-2011, 11:54 PM #71
OK! if the return current is going to the transformer, than it is the grounded conductor not the ground (by the way in theory the current and nuetral should zero out at point of use). so how can a 4 wire recept landed in a main distribution panel with no GEC landed on the neutral bar be properly protected? the recept is installed with intention of the ground and neutral containing the ability of seperate paths. One to close or carry return path of energy, the other to take path in case of a malfunction or path is interrupted by a conductive or non grounded source to earths ground.
10-09-2011, 12:09 AM #72
10-09-2011, 12:54 AM #73
NO!!! I'm saying it takes the energy to earth, A fault or trip will disrupted electrical flow, but the unused energy has to go some where!, that is why you have the ground electrode and grounded circuits tied into the earth.
what was the main purpose of developing the 4 wire recepticle? SO THE NUETRAL WAS NOT GROUND SOURCE TO APPLIANCES
if you see a metal cover on a recept do you check to see if the box is plastic or metal? using a metal cover on a plastic box or ungrounded box has potential to expose electrical energy to the occupent. think about it!! the hot wire makes contact to a conductive source and the person leaning on an appliance with a live conductor in use will get shocked when they touch the cover if not grounded.
10-09-2011, 01:10 AM #74
10-09-2011, 06:06 AM #75
Again you are continuing to confuse the difference between a GEC and an EGC. Read what the NEC says the purpose of the GEC system is intended for. What do you think the purpose of the bond screw or strap is? The fault current needs to get back to its source, not the earth.
(1) Electrical System Grounding. Electrical systems that
are grounded shall be connected to earth in a manner that
will limit the voltage imposed by lightning, line surges, or
unintentional contact with higher-voltage lines and that will
stabilize the voltage to earth during normal operation.
Do you realize that a breaker will trip if there is a short to the EGC or neutral and there is no rod? Have you done the math that Derek asked for?
(5) Effective Ground-Fault Current Path. Electrical equipment
and wiring and other electrically conductive material
likely to become energized shall be installed in a manner that
creates a low-impedance circuit facilitating the operation of
the overcurrent device or ground detector for high-impedance
grounded systems. It shall be capable of safely carrying the
maximum ground-fault current likely to be imposed on it from
any point on the wiring system where a ground fault may
occur to the electrical supply source. The earth shall not be
considered as an effective ground-fault current path.
10-09-2011, 06:27 AM #76
Why were you working on energized electrical equipment?
Can you site this requirement?how many of you that inspect a home with alminum wire note an annual inspection on that service for maintaining the circuits and connections? thats in the NEC code book!
How is an isolated tank becoming energized?speaking of lightning, homes on wells, do you check the tank (if metal) for ground? if the home is ran in a flex pvc/poly tube or none conductive material (except at the water heater for bond jumper if installed) what protects the plumbing from an electrical surge?
Given the lack of understanding of electrical systems that might be a hard claim to backup.and I guarantee none will be from my work, can you guarantee none of your homes inspected by you haven't or won't have an electrical fire or malfuntion that will injur or kill a client?
Why would a service fed with SE lack anything needed and how would it affect a 4 wire receptacle? Remember that breakers will trip without a grounding electrode. Or are you confusing the service with a 3 wire branch circuit fed with SE cable?so yes I will argue a 4 wire recept installed on an older service (Especially on an SE cable) would not provide proper protection of that circuit.
10-09-2011, 03:00 PM #77
were did I say amps/ohms/ or even voltage??? I said path interuption,fault, trip. But ok the only reason the neutral has a lower resistance is from the path of voltage, ground is a dead wire. so voltage is lost were is the resistance level than on that branch circuit neutral? in theory all unused power will travel back to the nuetral bar by path in circuit under normal use(while having voltage) but not when it is disrupted/intercepted pass the point of demand, nor will it cause the circuit to fault, that is why the ground can be used to close/complete/produce usible electricity with earths ground, you charge the ground with voltage the resistance is equal to a neutral.
take a light socket, pig tail it with the hot landed to 120V power leg, than touch the neutral wire to earth the bulb will light!
the reason I even mention the ground "IS" the ground wire's live with voltage and there goes your 5<6 ohms to trip the breaker, but it carrys current and is exposed to contact through the length of that circuit.
10-09-2011, 03:22 PM #78
Norman, I copied the following info from post 36 of this thread from another forum I belong to. You really need to read the following info and absorb it
Frequently Asked 2005 NEC Questions - Page 4Grounding Vs. Bonding
The Big Picture- What is “grounding”? What is “bonding”? What’s the difference?
The terms are defined in Article 100 and 250.2 of the NEC. Section 250.4 provides the performance requirements of Article 250. Grounding is a connection to earth, and bonding is the connection of items to each other.
Bonding is crucial inside a structure, because without it, if something goes wrong and an ungrounded conductor comes in contact with a piece of metal that someone can touch, that someone will receive a shock and potentially be electrocuted due to the uncleared fault. A quick and dirty definition for bonding is connecting electrical devices together in the attempt to trip a breaker, if an ungrounded conductor touches surface metal associated with the system.
What does the earth have to do with this? Nothing.
Then why is it called an “Equipment Grounding Conductor (EGC)” in the NEC if it’s primary purpose is to “bond” things together? Simple answer: tradition. It’s always been called that, and the terms in the NEC have served to confuse people for a long time. Proposals have been made to change the term, and progress has been made, but the EGC continues to hold it’s misnomer.
Electricity does not seek the path of least resistance to the earth. It seeks all available paths back to it’s source, in proportion to their resistance. The reason that a person gets shocked when touching an ungrounded conductor and the earth is because the neutral of the system is repeatedly connected to earth in a grounded electrical system. The earth becomes part of a return path to the transformer – it’s part of one route back to the source; the earth is not the destination for the electricity.
Driving a ground rod to ‘ground’ any electrical equipment does not provide the low-resistance path required to trip breakers. Driving a ground rod, or using a Ufer, or a metal water pipe is not a substitute for an EGC. A ground rod with 25 ohms to earth will allow almost five amps to escape the system into the earth when directly energized from a 120V source. Five amps will never trip a 15A or 20A breaker, and in the meantime everything bonded to this ground rod will be energized to 120V.
Bob Ludecke has created a powerpoint presentation under the 2002 cycle, and has granted permission for a link to be posted for download. Chris Knight has graciously provided a site for downloading the presentation:
Bob Ludecke's Grounding Presentation
Thanks to both Chris and Bob for their help on this very important topic!
http://www.mikeholt.com/graphics/touch.gif
http://www.mikeholt.com/graphics/touch2.gif
http://www.mikeholt.com/onlinetraini...16665767_2.gif
http://www.mikeholt.com/onlinetraini...16666050_2.gif
If any of the items discussed here does not make sense to you, or if you disagree, please start a thread publicly or send a private message to me to discuss it privately, if you desire. It is critical that this issue be understood to ensure the safety of everyone involved.
10-09-2011, 05:01 PM #79
I feel SE is reduced in providing a safe path for electricity. as mentioned the nuetral can be a bare conductor in SE cable, on a surface mount installation minimul damage can expose electricity, I think all service feeders should be insulated conductors. using SE on range runs is questionable on providing a safe circuit path. Disagree all you want, I have and will replace an SE cable service on any home I own, a rigid conduit riser, a secured insulater, an obvious drip loop and a fused (600V) disconnect grounded to a 5/8" 10' ground rod to reduce the chance of a energy surge from the power grid.
10-09-2011, 05:08 PM #80
10-09-2011, 05:18 PM #81
Your theory about cable damage totally ignores the Code prohibition about using that wiring method where subject to damage.
BTW, you still have not provided the code sites that have been requested. To recap, panels in kitchens, bedrooms or within 6' of running water; annual inspection of aluminum terminations. You also ignored why you would advise someone to take shortcuts by wetting the ground around a rod in order to pass inspection.
10-09-2011, 05:25 PM #82
10-09-2011, 08:49 PM #83
Forget it Jim, dude is clueless.
I am going to go argue with JP.
10-09-2011, 10:29 PM #84
10-10-2011, 06:46 AM #85
Where is the ungrounded "neutral" conductor from the line side?
10-10-2011, 05:28 PM #86
10-11-2011, 04:21 AM #87
