Results 1 to 4 of 4
Thread: recent changes
    Default recent changes
    Brian,
    As soon as you changed the 'Find A Home Inspector' to being above the 'Message Board' link on the right, the main technical board is not just a little too wide for my display settings, almost half of that column is now off screen.
    However, this part of the message board (non-technical) still loads the same as it always has.
    Did you make something wider at that technical board part?
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Default Re: recent changes
    Maybe we just need to get those "panoramic" monitors.
    Capistrano Beach, CA
    Thumbs up Re: recent changes
    Thanks Jerry.
    I bet your monitor is running in 1024x768 or less.
    I forgot to check my changes in different resolutions & browsers.
    It should be OK for you know.
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Quote Originally Posted by Brian Hannigan View Post
    Yes it is.
    Display 1 (my left display, where I keep my desktop icons and links) is set to 1152 x 864
    Display 2 (my right display, which I use most often until I work on two things) is also set to 1152 x 864
