Results 1 to 45 of 45
    Default Lets share a few of our pictures from the week!
    All in all it was a pretty normal week. The pictures need no titles or descriptions!
    Default Re: A few of my inspection findings from this week!
    A few of mine. Mine was not as exciting as Scott's week seeing some ass and all.
    archivoyeur's Avatar
    archivoyeur Guest
    Scott,
    I don't see anything wrong with adding a lirtle extra insulation to your crawl space. They were just ging to let that dryer lint blow away anyway.
    (We used to teach scouts to make fire starters with dryer lint and a drop of candle wax. After you do that once you RUN home and check the filter.)
    archivoyeur Guest
    Rick,
    I give.
    What is going on with the water heater?
    Hey , Who you calling an A$$ HEEEEEEEEEEEEHAAAAAWWWWWWWWWW
    Here's a classic, but I can't decide to file it under electric or plumbing defects?
    Actually both electric and GAS (unless you put gas in with plumbing).
    Knew that Jer, was just testing the waters. Now who wants to post the code refs for these reportable defects?
    (Jerry P, you be still)
    I'll play along. Here's my week in 10 pics. My dryer hose looked just like yours, Scott.
    Ron Bibler's Avatar
    Ron Bibler Guest
    This is one of my best IR shots to date...
    Termites in a floor with a bad case of gas
    Ron, is that a termite hole spouting cool air? It's an amazing shot!
    Ron Bibler's Avatar
    Ron Bibler Guest
    You are very close John. Its liquid air... I injected the termite hole with liquid air and the void in the hard wood flooring that the termites had excavated was now under pressure with the liquid air. You could not see this without the INFRARED CAMERA.
    That's why you make the big buck while I'm inspecting this .........
    Inspector 3500's Avatar
    Inspector 3500 Guest
    Rick, what is under the down spout? Is it the end of a prestressed cable?
    RB: So where does one obtain liquid air?
    You can gathert it when you pass gas but it is almost liquid.
    Quote Originally Posted by Inspector 3500 View Post
    Yes Sir! Its the exposed end of a Post-Tension Cable.
    From the looks of it, it was never covered.
    Zeeland Michigan
    This is a first for me. Condensate drain line made of copper to the top of a toilet tank. The last photo is a catv cable thru a light fixture.
    What a deal!
    If a man empties his purse into his head no one can take it away from him. An investment in knowledge always pays the best interest
    Benjamin Franklin
    A couple of hazards from the morning inspection.
    Ron Bibler's Avatar
    Ron Bibler Guest
    No way I moving to TEXAS... They have Snakes
    What the heck is that Rick?
    RB: Cottonmouth.
    Apr 2009
    Manchester, Vermont
    I loved the photo's you H.I.'s put in.
    Rich H. QUESTION: water tank in attic, storage or in used.
    gainesville fl
    All I got is 5000 sq ft EIFS from hell just 2 of over 300 from this inspection.
    Mount Pleasant, SC
    Two decent ones from this week...
    The classic improper dryer vent and a No Handrail section in a new construction 600K...
    www.atozinspector.com
    Mount Pleasant, SC
    Quick question, why do so many of you guys not date stamp your photos?
    gainesville fl
    I'll see your hand rail a raise you one
    regarding date stampes, all can be doctored and all digital pic have a lot of info imbedded as in pic 3
    "Missed it by that much 99"
    Atlanta, Georgia
    Quote Originally Posted by Mike Gault View Post
    I crop at least one third of the pictures before adding to the report. Date would be cut off some and not others and could raise questions.
    They clutter up the photo and take away from the important bit, the defect.
    All the pictures from each inspection go into a dedicated folder. All the interior shots had to be taken the day of the inspection because that is the only time I had access.
    Why would I add it?
    I have done it both ways in the past and found no reason to include it. All the photos of the report are included in a dated report, so the individual date stamps are superfluous and distracting. Unless I am needing to document the date and time in every single shot it is just clutter. Unlike others that want to provide an information overload, I try to keep the report clean, readable with pertinent information so that the client can actually find useful information without reading War and Peace.
    64-year old POS this A.M. in Oak Cliff with new granite counters, stainless steel appliances, and new bathroom, and . . . thought I was in Philly.
    Hey
    But it had remodeled kitchens and baths and how about those granite counter tops????
    By the way. Your third pic. Who thru the mud all over the bottom of the beam.
    Mike Gault
    I agree with Jim and Bruce. The pics are going into a folder for that day for that home for that client and your computer dates when you down loaded them and even the time and how many pictures.. They are also going into the report of an inspection that you did on that day. No need for another date stamp for the pics. Also the pics are numbered in sequence for when you took them on that day. The pics in the report correspond with what you write in your report for that inspection. Date stamping is overkill and clutter.
    TM: Reticulitermes flavipes.
    TM: Agreed. Besides, many of today's cameras are not so equipped.
    Aaron, Ted,
    Agreed. Not only is in not necessary, clutters up the photo, but is meaningless when it comes to trying to prove when the photo was actually taken.
    Besides, that cluttered up part of the photo may be hiding something you may have wished you had spotted, and would have spotted if not for the date stamp.
    JP: Agreed.
    Quote Originally Posted by Robert S. Mattison View Post
    Water heater was located in the attic of the home and was operable.
    Mount Pleasant, SC
    I turned the date off tonight (wife hated it anyway :-).
    All very valid points....
    Fuquay Varina, NC
    I stopped using dates on photo's for the purpose of using the photo's in other reports. For instances I'll take pictures of correct installation of Flashing around a window or Condensate drains and traps on hvac. Then I use them as examples when I find one wrong. But then I have to write in caps "EXAMPLE OF drains and traps on ANOTHER HOME" which would cover up that date stamp anyway. Oh well ......
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
  40. #40
    Mount Pleasant, SC
    Here's a Primary condensate from today that terminates in the crawlspace (installed August 2007) and the resulting 'puddle'...
    Notice No Dates! I'm conforming :-)
  41. #41
    Ron Bibler's Avatar
    Ron Bibler Guest
    Ever have one of these leak on you
  42. #42
    Apr 2009
    Manchester, Vermont
    Ron a basement sh-t pump it something I never want to smell again.
    If I smell it, start throwing-up. I'll pass on the job, if the customer think
    I should open one up as part of the H.I. inspection.
    The other is a crawl space, where the owner has cats, and the cats use it
    as their own personal litter box.
    I once watch a guy, up wind, go into a large oil storage tank, to clean out
    a plug fuel line. And get this, he did it without a personal mask breather.
    Last edited by Robert Mattison; 08-30-2009 at 12:00 PM. Reason: for spelling error
  43. #43
    Fuquay Varina, NC
    I just run the water long enough to get the pump to run then shut off to make sure the one way valve works. They are plastic and make a loud thump when sealing. If the valve doesn't work it will sound like a tidal wave coming back in.........
  44. #44
    Apr 2009
    Manchester, Vermont
    Mike S.
    Like your solution, to that problem, mind if I use it, with future customers.
    /S/ Robert
  45. #45
    Jul 2007
    Phoenix, AZ
    Here is some free advice. Google Picasa photo software and download it, it's free, and has a great editing feature that allows you add in fill light to the pictures. really handy when trying to see detail, since a lot of pics posted here could use some extra clarity. Saves going back to redo a bad shot.
