Results 1 to 14 of 14
    so so, California
    Default Dog pee all over the place...
    I was bummbed, my bag was sitting in a huge wet spot... Oh, BTW, I have 10 images just like these.
    Default Re: Dog pee all over the place...
    Without lab tests, how can you be sure it was DOG pee?
    Taste ?
    Ewwwwww!!!!!
    Although once we did a house that was littered with dog poo. Bob took one look and went outside to pull on his tyvek suit and respirator before going inside.
    Welmoed Sisson
    so so, California
    It was a guess judging by the unbearable odor in the house.
    Aug 2011
    Quote Originally Posted by Welmoed Sisson View Post
    Ewwwwww!!!!!
    Just crawled a crawlspace where the former occupant had apparently kept the dog......nuff said.
    Over the years the two things that I've done to rid the fixers that I've had with dog and cat pee is this: Rent an ozone generator and park it in the house for three days. Of course, ozone is toxic, so when I return to turn it off, I get a big breath of air and open doors and windows, etc. Return to the car, and leisurely eat my Sonic breakfast burrito. Ozone is amazing at neutralizing these kind of odors and smoke, too.
    Then, seal everything with Kilz.
    So, far 100% success.
    Aug 2011
    That fact sheet appears to be directed to very low information folks with the intent of just dissuading them from using an ozone generator, rather than trying to educate them in how to effectively use one. Ozone doesn't "clean" anything.
    At the risk of over-simplifying this, organic odors from things like dog pee, burnt wood, etc have an open connection that attaches to odor receptors in our nose creating what we smell. Ozone has an extra oxygen atom. The extra oxygen atom on an ozone molecule binds to that receptor and that "odor molecule" can no longer attach to our nose receptors. Thus the ability of dog pee to stink is neutralized, but the dog pee is still there and should be sealed. Abrasion of the pee surface can expose non-neutralized pee and the odor can return.
    The fact sheet doesn't acknowledge that ozone generators used for the purpose of neutralizing odors from an organic source are, in fact, very effective. Properly used, ozone is a great tool, but like any tool, improper use is dangerous.
    Some of you may remember that I bought a house 5 years ago in Atlanta for my Son.
    He has since moved back to Tennessee and now I have a rental property 120 miles away.
    Anyhow, the previous owner had a dog (or 10).
    We power washed the garage floor, deodorized it, yet 5 years later it's still in the garage.
    And tenants ask "Why don't you allow dogs, my are house trained".
    Don't get me wrong, I love the little critters, I've got two.
    But they pee/Poo in MY house. It's my house.
    I've used this OdoBan 128 oz. Eucalyptus Odor Eliminator-911061-G at The Home Depot ( other scents are available ) Cat Pee laminate flooring. Thought I would have to rip it all out. Mixed a little stronger concentrate after a day or so No Smell ( the Odor bon has a scent ) NO SMELL !
    I've used Odor ban for a few years.
    It helped, but did not eliminate the odor.
    I think it's because the dog(s) were in the garage all the time.
    unsealed concrete floor acted like a sponge to soak it in.
    One day I may finish the garage floor.
    Aug 2011
    We had a cat for awhile that sprayed. I tried some pretty high dollar things, but regular Oxiclean worked as well as anything and it's cheap enough that you can dose it on pretty heavy.
    Hi, ALL &
    Reminds me of a House from a couple of years back - 2-3 years-old, only...
    Finished outside and began upstairs, as usual and began noticing the baseboards & lower door trims (all MDF, luckily) were swollen and distorted in the main hallway and inside most every room.
    Called to my Client and pointed this out, suggesting this was pet urine (although my mind had begun to wander and I even though "what if the doggies were NOT responsible ?" - expecting the Client to run for it.
    They asked "what to do..." I stated immediately pull-up all floor finishes and the carpet underlay and purge it all, then would tear-out all the affected trims and ultimately would need to 'NUKE' the sub floor (ie. Agent Orange or something else, to drive home the seriousness)...
    Believe they ran-for-the-hills, as expected, however it was never confirmed (nor did they ever come back to me on a 'next' inspection).
    Go figure !
    -Glenn Duxbury, CHI
    Dec 2009
    Florida
    Zinssler is good too---Shellac base only, not water base on any sealer. You will have problems later with the water based.
