    Default hose bib close to garage floor
    Probably one of those common sense things...
    Is there a minimum height above grade or above the floor for a hose bib?
    This one barely has room to attach a hose without kinking it.
    Ray Norton's Avatar
    Ray Norton Guest
    Default Re: hose bib close to garage floor
    I could not find any code that governs the height of the hose bib.
    Nampa, Idaho
    I would not mention it.
    Tom Thompson's Avatar
    Tom Thompson Guest
    Atmospheric vacuum breakers are required to be minimum 6" above surrounding ground, other than that it's user preference.
    Quote Originally Posted by Tom Thompson View Post
    Where's that come from and what's the reasoning?
