    David J. Edens's Avatar
    David J. Edens Guest
    Default Attic Pull-Down Stair Heights?
    What is the typical standard height for a pull-down staircase to be installed and more importantly, what is the maximum ceiling height in which one can be installed-at least without being custom built? Thanks
    Default Re: Attic Pull-Down Stair Heights?
    Quote Originally Posted by David J. Edens View Post
    DE: There are many manufacturers of these units. Check out their sites and see what the tallest available is:
    www.memphisfoldingstairs.com/
    https://www.louisvilleladder.com/
    www.wernerladder.com/
    www.rainbowatticstair.com/
    Folding attic stairs, folding attic ladders and specialty windows from Century Industirs - Premium Home Products built for relability, safety and quality
    Stira Folding Attic Stairs, manufacturers of high quality wooden attic stairs.
    Precision Ladders, LLC
    Depends on the stair, but I've seen them for 12 foot ceilings, the stairs were one piece sliding ones similar to this (may have been this): http://www.bessler.com/100.html
    JP: When Overhead Door was making the units they would make them as long as you wanted - within reason, of course.
    With a one piece stair which pulls down and is counter balanced, it can be as long as the trees grow tall ... wait, that's a "stair" and the maximum height between landings is 12 feet, is it not? ... Oh, wait, those are actually "ladders" - ummm ... okay.
    JP: I sincerely hope that you are not off to designing a prototype unit with 3' X 3' landings. Stop it!
