    Apr 2009
    Manchester, Vermont
    Cool Worn out 2-wire duplex receptacles
    Can any member direct to a site where they speak about worn female
    receptacle that can no longer hold tight the male plug.
    I need facts, to show a customer. Thanks.
    Southwest US
    Default Re: Worn out 2-wire duplex receptacles
    Quote Originally Posted by Robert Mattison View Post
    I am having this same issue in my marriage, I'm glad somebody finally brought it up. I am interested in all replies. If your customer doesn't believe you, give him 20 years.
    Robert, you could just point out that loose connections cause heat to build up and create a hazard.
    Chicago
    Hello Robert,
    That is addressed in NFPA 73. I don't have my copy in front of me right now but will post it later.
    Sincerely,
    Corey
    Garland, TX
    http://communities.leviton.com/servl...ec%20RTT99.pdf
    you'll have to read down for dwelling info
    NFPA 73, 1996 Edition
    Chapter 2 Section 2-10.7 General Requirements
    Receptacle contacts shall have acceptable blade retention when tested with a listed retention tester.
    dana1028's Avatar
    dana1028 Guest
    Quote Originally Posted by Corey Friedman View Post
    Hello Robert,
    Sincerely,
    Corey
    For the record - NFPA is rarely adopted by a local municipality and thus is not a code requirement and should not be used as a legitimate source citing an alleged noncompliant situation.
    Chicago
    Quote Originally Posted by dana1028 View Post
    Hi Dana,
    The NFPA is an organization and has not adopted anywhere.
    Various NFPA codes and standards that they publish are adopted. I'm not sure I follow what you are saying.
    The OP said nothing about code compliance. The OP asked for a reference and I provided one. Are you saying that you don't consider the NFPA a credible source (regardless of a particular document being adopted locally)?
    The OP said nothing about this being a code battle.
    Sincerely,
    Corey
