    David J. Edens's Avatar
    David J. Edens Guest
    Default Fibrous Siding ?
    Default Re: Fibrous Siding ?
    Quote Originally Posted by David J. Edens View Post
    When is generally the last year(s) that fibrous (Masonite-type) siding was used?
    DE: The last date included in the class action suit was May of 2000.
    You think a class action law suit stops manufacturers from producing stuff like that?
    Are you sure it is not still available?
    Last edited by Jerry Peck; 04-15-2009 at 09:25 AM. Reason: added smiley face I forgot to add
    JP: That's not what I said, or believe, for that matter.
    JP: I haven't seen it installed in years.
    Aaron,
    Oops ... forgot the smiley face ... went back and added it with edit.
    LP "SmartSide" looks like an updated version of their previous siding. I would guess that various forms of fiber or OSB siding are still available.
    GA: SmartSide is OSB with veneer. A pig with lipstick. For the word hounds out there, the whole hardboard siding problem revolved around "edge welt". One can only wonder what the detrimental issue will be with SmartSide.
    A.D.
    I thought that was what Inner-Seal was. OSB with a resin paper over the face.
    A.D.
    GA: From their brochure. Take a closer look.
