    Default Garage door header
    Doubled 2x18 glue lam. 20 foot span. Same as in the approved plans. Deflection of 5/8 inches over that span.
    Center section under poor doorhead flashing is wet and could dig in 3/4 inch with Awl.
    Soft over the center 4 feet or so.
    Sag noted at exterior blocked trim which has opened at blocked joints.
    Any thoughts on the degree of deflection.
    We have a SE coming but I was wondering what you guys think.
    Thanks, Wayne
    Default Re: Garage door header
    Thanks, Wayne
    All right what have you done with the REAL WAYNE ! ( aka. old Silver Back )
    All I can say whoever you are It,s a Goner.
    Tell the SE to hurry!
    Ron Bibler's Avatar
    Ron Bibler Guest
    Remove and replace. "INKIND".
    That's good Billy, Got tierd of looking at the same old Monkey. Thats a pic of my home in Thailand where I should be RIGHT NOW!!!
    Thanks guys, That was my interpretation in a few more well picked words I might add. Contractors already 250 grand in the bag with more to go.
    Ooooo many , many, Baht.
    You going to let him up anytime soon ?
    Lancaster, CA
    gainesville fl
    Tell them not to forget the Z flashing this time.
    This was fixed a month ago. Had the SE go out and concurred that the beam was affected by the leak and would require replacment. Contractor was pissed as usual, which means I did my job. The flashing problem was due to the designer insisting on a trim block in the center of each door head that made the flashing a little more difficult and apparently more than the brain surgeon could handle.
