    Andy Jarchow's Avatar
    Andy Jarchow Guest
    Default Any idea what gauge these are?
    Hello all,
    Any idea what gauge these aluminum main wires feeding the main panel are?
    They are in a 150 amp box with 150 amp main breaker.
    Thank you!
    Default Re: Any idea what gauge these are?
    The minimum size to properly serve a 150 amp service would be 2/0 AL.
    Roger Frazee's Avatar
    Roger Frazee Guest
    They look like 1/2" to me ...
    Seriously I think Jim has the best answer . I'm not real sure what the HI's use to determine a wire size if they can't see the awg on the outer covering. Is there any particular reason you suspect the wire size being incorrect...?
    Andy Jarchow Guest
    Hello,
    I go by what size they appear to be. To me they look like they could be 1/0.
    I should get some of the sizes I'm not as familiar with to compare. I checked with a sparky several month ago but he never got back to me.
    Thank you all!
    On The Mason-Dixon Line
    completely impossible to tell the awg of a electrical conductor in a picture.
    Unless it is a close up and actually shows the awg size printing on the cable, other then that it is a 100% total guess
    Andy Jarchow Guest
    No awg on the wire. I was hoping a sparky would be able to compare the main feed wires in the pic to the branch wires and give me an educated guess. It was worth a try.
    Thank you all
